I have just received my NodeMCU V3 utilizing 32M of addressable storage. I have just plugged it in, and I was first met with the fact that the Arduino IDE with the Arduino IDE plugin for ESP8266 devices does not have a NodeMCU V3 option, rather 2 options for NodeMCU 0.9 and NodeMCU 1.0.
With some research into how to set one up, I have utilized this tutorial from Instructables. Which states at the beginning to flash the NodeMCU with some firmware.
However, not being to certain if that is a good idea (as I have broken microcontrollers through faulty installs
This lead however to some errors whilst uploading, using the verbose reply system for upload, the following errors are received:
C:\Users\Nebula\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.13/esptool.exe -vv -cd nodemcu -cb 115200 -cp COM4 -ca 0x3FC000 -cz 0x4000 -ca 0x00000 -cf C:\Users\Nebula\AppData\Local\Temp\build462236accad2415310c5b24cce7ccca0.tmp/Blink.ino.bin
esptool v0.4.13 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to nodemcu
setting baudrate from 115200 to 115200
setting port from COM1 to COM4
setting address from 0x00000000 to 0x003FC000
setting erase size to 0x00004000
setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
flush start
setting serial port timeouts to 1 ms
flush complete
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
warning: espcomm_sync failed
error: espcomm_open failedI am using these settings for my board.
What is the course of action to at least get the Blink program to operate. Any help would be greatly appreciated.
