The ESP01s relay is https://www.aliexpress.com/item/ESP8266 ... 26507.html
The 230v/5v buck is https://www.aliexpress.com/item/AC-DC-5 ... 95138.html
The connection is good and I was able to control the switch via web interface.
Explore... Chat... Share...
schufti wrote:Use board search, has been discussed several times
