I have a troubles with getting access to WLAN secured by WPA2-Enterprise EAP-TLS using ESP8266 and Arduino IDE. Is there any solution, to do it?
I have p12 certificate to do connect, so I extracted from it two files privateKey and publicCert and turned both to *.h files. Using joostd's code which can be found here I can't get access to wlan. Even Radius doesn't have any trace of try to connect by my ESP.
But, there is another code which leave a trace on Radius, but Radius shows that "Client doesn't support EAP." I know, that ESP8266 supports eap-tls connection. So, how can I solve this problem? Any solutions? Has anybody solve the same or similar issue?
Here is a code which leave the trace in Radius, but can't get access (I don't know author):
extern "C" {
#include "user_interface.h"
#include "wpa2_enterprise.h"
#include "c_types.h"
// SSID to connect to
char ssid[] = "ssid";
char wlpasswd[] = "";
char username[] = "user";
char identity[] = "user";
char password[] = "";
char new_password[] = "";
const char* username1 = "user1";
u8 ca_cert[] = "-----BEGIN CERTIFICATE-----\n"
"................here is my certificate...............\n"
"-----END CERTIFICATE-----";
WiFi.mode(WIFI_STA);
delay(1000);
Serial.setDebugOutput(true);
Serial.printf("SDK version: %s\n", system_get_sdk_version());
Serial.printf("Free Heap: %4d\n",ESP.getFreeHeap());
// Setting ESP into STATION mode only (no AP mode or dual mode)
wifi_set_opmode(STATION_MODE);
struct station_config wifi_config;
memset(&wifi_config, 0, sizeof(wifi_config));
strcpy((char*)wifi_config.ssid, ssid);
strcpy((char*)wifi_config.password, wlpasswd);
wifi_station_set_config(&wifi_config);
wifi_station_set_wpa2_enterprise_auth(1);
// Clean up to be sure no old data is still inside
wifi_station_clear_cert_key();
wifi_station_clear_enterprise_ca_cert();
wifi_station_clear_enterprise_identity();
wifi_station_clear_enterprise_username();
wifi_station_clear_enterprise_password();
wifi_station_clear_enterprise_new_password();
wifi_station_set_enterprise_identity((uint8*)username1, strlen(username1));
wifi_station_set_enterprise_ca_cert(ca_cert, sizeof(ca_cert));
wifi_station_set_enterprise_identity((uint8*)identity, strlen(identity));
wifi_station_set_enterprise_username((uint8*)username, strlen(username));
//wifi_station_set_enterprise_password((uint8*)password, strlen((char*)password));
//wifi_station_set_enterprise_new_password((uint8*)new_password, strlen(new_password));
//wifi_station_set_enterprise_ca_cert(ca_pem, ca_pem_len);
wifi_station_connect();
delay(1000);
Serial.print(".");
}Problem solved!
