I am busy with a diy alarm system and i am having issues with the following:
I bought these esp01 devices. https://www.aliexpress.com/item/Upgraded-version-ESP-01-ESP8266-serial-WIFI-wireless-module-wireless-transceiver-ESP01-ESP8266-01/32341788594.html
I want to create a simpel mqtt device that sends a message when a magnetic sensor is open.
Here for i am using the following code:
#include <PubSubClient.h>
#include <ESP8266mDNS.h>
ADC_MODE(ADC_VCC);
//USER CONFIGURED SECTION START//
const char* ssid = "YOUR_WIRELESS_SSID";
const char* password = "YOUR_WIRELESS_SSID";
const char* mqtt_server = "YOUR_MQTT_SERVER_ADDRESS";
const int mqtt_port = YOUR_MQTT_SERVER_PORT;
const char *mqtt_user = "YOUR_MQTT_USERNAME";
const char *mqtt_pass = "YOUR_MQTT_PASSWORD";
const char *mqtt_client_name = "PICK_UNIQUE_WINDOW_NAME"; // Client connections cant have the same connection name
const char *mqtt_topic = "PICK_UNIQUE_WINDOW_TOPIC";
IPAddress ip(192, 168, 86, 48);
IPAddress gateway(192, 168, 86, 160);
IPAddress subnet(255, 255, 255, 0);
//USER CONFIGURED SECTION END//
WiFiClient espClient;
PubSubClient client(espClient);
// Variables
bool boot = true;
char batteryVoltageMQTT[50];
//Functions
void setup_wifi()
WiFi.config(ip, gateway, subnet);
WiFi.begin(ssid, password);
delay(50);
void reconnect()
while (!client.connected())
int battery_Voltage = ESP.getVcc() + 600;
String temp_str = String(battery_Voltage);
String mqttString = temp_str + "mV Replace Battery";
mqttString.toCharArray(batteryVoltageMQTT, mqttString.length() + 1);
if (battery_Voltage <= 2900)
if (client.connect(mqtt_client_name, mqtt_user, mqtt_pass, mqtt_topic, 0, 1, batteryVoltageMQTT))
if(boot == true)
client.publish(mqtt_topic,"open");
boot = false;
ESP.restart();
if (battery_Voltage > 2900)
if (client.connect(mqtt_client_name, mqtt_user, mqtt_pass, mqtt_topic, 0, 1, "closed"))
if(boot == true)
boot = false;
ESP.restart();
void setup()
setup_wifi();
client.setServer(mqtt_server, mqtt_port);
void loop()
if (boot == true)
reconnect();
ESP.deepSleep(0);
My wiring is as follows:
The device works but the battery drain is high.
I have used normal aa battery`s and rechargeable 2000 mah battery`s but i get 2 days tops.
Looking ad other projects i see people getting 6 months till a year of battery life.
I am sure i am missing something but i cant find it.
Can someone please have a look at it and point me in the right direction?
Thanks in advance.
