I have some troubles with my ESP8266. I use NodeMCU ESP8266 v2 with SDK version: 2.2.1(cfd48f3). I also use Arduino IDE with ESP8266 libraries (latest). My problem is wdr reset. I don't have any idea why it happens, so maybe you can help me.
So, my code is here:
extern "C" {
#include "user_interface.h"
#include "wpa2_enterprise.h"
#include "c_types.h"
#include "cert.h"
static const char* ssid = "xxx";
char identity[] = "xxx";
void setup(){
delay(2000);
Serial.printf("Connecting to %s\n", ssid);
if (!wifi_set_opmode(STATION_MODE)) {
Serial.print("STATION_MODE isn't set");
struct station_config wifi_config;
memset(&wifi_config, 0, sizeof(wifi_config));
strcpy((char*)wifi_config.ssid, ssid);
wifi_station_set_config(&wifi_config);
wifi_station_clear_cert_key();
wifi_station_clear_enterprise_ca_cert();
wifi_station_clear_enterprise_username();
wifi_station_set_wpa2_enterprise_auth(1);
wifi_station_set_enterprise_identity((uint8*)identity, strlen(identity));
wifi_station_set_enterprise_cert_key((uint8*)user_cert, sizeof(user_cert), (uint8*)user_key, sizeof(user_key), (uint8*)user_key_pass, sizeof(user_key_pass));
Serial.print(".");
Serial.println("");
delay(1000);
WiFi.forceSleepBegin();
void loop()
}And when the ESP8266 is connected to the internet, I try to set my ESP to sleeping mode (disconnect from WiFi etc. for saving power. And then, in the last line of code (WiFi.forceSleepBegin();) there is a situation...
I got such a response from ESP in serial monitor:
WiFi connected
IP address:
xxx.xx.xx.xx
Exception (3):
epc1=0x4010011d epc2=0x00000000 epc3=0x00000000 excvaddr=0x40071128 depc=0x00000000
ctx: cont
sp: 3ffffc10 end: 3fffffd0 offset: 01a0
>>>stack>>>
3ffffdb0: ffffffff 00000000 3ffeb2e1 00000008
3ffffdc0: 40231106 3ffeea68 3ffeea68 3fff120c
3ffffdd0: 3ffef56c 0000003c 4010106b 3ffeea68
3ffffde0: 00000000 40231aec 00000000 00000006
3ffffdf0: 013b17ac 00ffffff 4c3b17ac 3fff14b4
3ffffe00: 40243d48 00000000 00000000 402096e1
3ffffe10: 3fff0c28 000001bd 000001bd 4010020c
3ffffe20: 3fff120c 3ffef56c 3ffefdc8 401006dc
3ffffe30: 00000000 3fff15d4 3ffefdc8 4010658c
3ffffe40: 4021e580 3ffefdc8 3fff15d4 4021e598
3ffffe50: 00000000 00000000 4021c235 3fff120c
3ffffe60: 4021c35d 3fff120c 00000008 3fff1224
3ffffe70: 40244130 3fff120c 0000049c 00000000
3ffffe80: 40239d8c 3fff120c 00000000 00000001
3ffffe90: 3ffe9509 3ffefdc8 3ffef56c 00000000
3ffffea0: 4021d124 00000000 00000000 00000000
3ffffeb0: 40238c61 3ffe9509 00000000 00000000
3ffffec0: 40238de7 00000000 00000000 40238d9b
3ffffed0: 3fffdad0 00000001 00000001 3fff1c14
3ffffee0: 40238eaa 00000000 00000000 00000001
3ffffef0: 40202650 3fff0c04 3ffe952c 3fff0c04
3fffff00: 40238c1a 00000000 3fff0aa8 3fff0bb0
3fffff10: 3fffdad0 3fff0aa8 00000000 4020269d
3fffff20: 3ffe8550 3fff0aa8 3fff0af0 402025bc
3fffff30: 702d7776 75646f72 6f697463 0000006e
3fffff40: 00000000 00000000 00000000 00000000
3fffff50: 00000000 00000000 00000000 00000000
3fffff60: 00000000 00000000 00000000 00000000
3fffff70: 00000000 00000000 00000000 00000000
3fffff80: 00000000 00000000 00000000 00000000
3fffff90: 00000000 00000000 00000000 00000000
3fffffa0: 40203340 4c3b17ac feefeffe feefeffe
3fffffb0: feefeffe 00000000 3fff0ba8 40203050
3fffffc0: feefeffe feefeffe 3ffe952c 40100739
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(1,6)
ets Jan 8 2013,rst cause:4, boot mode:(1,6)
wdt reset
Any solutions? I read that people with similar issue just use yield() or delay(0) and it solved their troubles...
Can anybody help me? I will be really grateful.
Best regards,
Scott.
