Page 1 of 4
NODEMCU with CCS811
PostPosted: Tue Oct 23, 2018 9:39 am
by Rerode
Hello all,
I connected a nodemcu with a CCS811.
Yesterday when i tryed it for the fist time i did receive CO2, VOC and Temperatuur.
But when i recconect is i receive this:
Code: Select all⸮CCS811 test
Failed to start sensor! Please check your wiring.
Soft WDT reset
ctx: cont
sp: 3ffffda0 end: 3fffffd0 offset: 01b0
>>>stack>>>
3fffff50:  3ffee6f8 00000031 3ffee7b4 4020323c
3fffff60:  3ffee6f8 3ffee7b4 3ffee7b4 40203385
3fffff70:  3ffe88d8 3ffee784 3ffe850c 40203385
3fffff80:  3ffe887c 3ffee7f0 3ffee7b4 402033b0
3fffff90:  4020159e 00001388 3ffee7b4 402033d4
3fffffa0:  feefeffe 3ffee7b4 00001388 402029f4
3fffffb0:  3fffdad0 00000000 3ffee7e8 402039c0
3fffffc0:  feefeffe feefeffe 3ffe850c 401000e5
<<<stack<<<
H!⸮⸮⸮⸮D⸮
This is the Arduino code
Code: Select all#include "Adafruit_CCS811.h"
Adafruit_CCS811 ccs;
  Serial.begin(9600);
  Serial.println("CCS811 test");
  if(!ccs.begin()){
    Serial.println("Failed to start sensor! Please check your wiring.");
    while(1);
  //calibrate temperature sensor
  while(!ccs.available());
  float temp = ccs.calculateTemperature();
  ccs.setTempOffset(temp - 25.0);
  if(ccs.available()){
    if(!ccs.readData()){
      Serial.print("CO2: ");
      Serial.print(ccs.geteCO2());
      Serial.print("ppm, TVOC: ");
      Serial.print(ccs.getTVOC());
      Serial.print("ppb   Temp:");
      Serial.println(temp);
    else{
      Serial.println("ERROR!");
      while(1);
I really don't understand why its not working any more.
I have also tryed a ESP-32 with the same results
Re: NODEMCU with CCS811
PostPosted: Tue Oct 23, 2018 10:16 am
by QuickFix
Where's the sketch of this example?
We really need more than this to go on.
My initial guess is (since it's a soft watchdog reset) is that there are no (or not enough) yields() or delays() in the code to give the WiFi-stack air to breath.
But again: one can only guess without an actual sketch and/or schematic. :idea:
PostPosted: Tue Oct 23, 2018 11:55 am
by Rerode
Thanks for the reply. I have updated the OP.
PostPosted: Tue Oct 23, 2018 1:09 pm
by Bonzo
When I first started using a Nodemcu I had errors like that and found that when I was trying to error check my code I put in serial print statements and the errors stopped! Purely by accident I found replacing the serial prints with small delays stopped the errors.
