How do I display on a website a directory of all the files available inside the sdcard (like the listfiles example) and download the text files over the internet?
I have tried to display a directory to a website using the code below but it it always tells me that 'client' isnt declared in this scope. I'm not sure how to download the file either. I was thinking of the user using 192.168.x.xxx/dir to see the files he could download and when he sees a file named "1.txt" , typing 192.168.x.xxx/1.txt or 192.168.x.xxx/2.txt will download the respective files to his computer.
#include <ESP8266WebServer.h>
#include <SPI.h>
#include <SD.h>
File root;
const char* ssid = "-----";
const char* password = "------";
WiFiServer server(80);
// Open serial communications and wait for port to open:
Serial.begin(9600);
//while (!Serial) {
// wait for serial port to connect. Needed for native USB port only
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
// Start the server
server.begin();
// Print the IP address
Serial.print("Connection IP: ");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.println("/");
Serial.print("Initializing SD card...");
if (!SD.begin(15)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
if (!client) {
return;
Serial.println("new client");
while (!client.available()) {
delay(1);
String request = client.readStringUntil('\r');
Serial.println(request);
client.flush();
// Match the request
if (request.indexOf("/dir") != -1)
root = SD.open("/");
printDirectory(root, 0);
void printDirectory(File dir, int numTabs) {
while (true) {
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println(""); // do not forget this one
client.println("<!DOCTYPE HTML>");
client.println("<html>");
File entry = dir.openNextFile();
if (! entry) {
// no more files
break;
for (uint8_t i = 0; i < numTabs; i++) {
client.print(':');
client.print(entry.name());
if (entry.isDirectory()) {
client.println("/");
printDirectory(entry, numTabs + 1);
} else {
// files have sizes, directories do not
client.print("\t\t");
client.println(entry.size(), DEC);
entry.close();
client.println("</html>");
