I have the following code running on a HUZZAH ESP 8266. The code runs well and logs T/H on my server but when I insert the following line of code
ESP.deepSleep(sleepTimeS * 1000000);Even if I put the line of code in the
void loop()void gettemperature()Any clues?
Thanks
/***************** LOAD LIBRARIES ********************************************/
#include <WiFiClient.h>
#include <DHT.h>
/************************* DHT22 Sensor *************************************/
#define DHTTYPE DHT22
#define DHTPIN 5
/************************* WiFi Access Point Settings ***********************/
const char* ssid = "myssid";
const char* password = "my-PASS";
/**************Initialise the DHT sensor ***********************************/
DHT dht(DHTPIN, DHTTYPE, 11); // 11 works fine for ESP8266
float humidity, temperature; // Values read from sensor
//String webString=""; // String to display
// Generally, you should use "unsigned long" for variables that hold time
unsigned long previousMillis = 0; // will store last temp was read
const long interval = 2000; // interval at which to read sensor
byte mac[6]; // the MAC address of your Wifi shield
char server[] = "192.168.0.52";
// Time to sleep (in seconds):
const int sleepTimeS = 20;
WiFiClient client;
void setup(void)
// You can open the Arduino IDE Serial Monitor window to see what the code is doing
Serial.begin(115200); // Serial connection from ESP-01 via 3.3v console cable
delay(100);
Serial.println(); // We start by connecting to a WiFi network
Serial.print("Attempting to connect to WPA2 network ...");
Serial.println(ssid);
dht.begin(); // initialize temperature sensor
WiFi.begin(ssid, password); // Connect to WiFi network
Serial.print("\n\r \n\r Working to connect");
// Wait for connection
Serial.print(".");
Serial.println("");
Serial.print("WiFi connected to ");
Serial.print("IP address: ");
WiFi.macAddress(mac);
Serial.print("MAC: ");
Serial.print(mac[0],HEX);
Serial.print(":");
Serial.print(mac[1],HEX);
Serial.print(":");
Serial.print(mac[2],HEX);
Serial.print(":");
Serial.print(mac[3],HEX);
Serial.print(":");
Serial.print(mac[4],HEX);
Serial.print(":");
Serial.println(mac[5],HEX);
// Give the server some time to recieve the data and store it. I used 120 seconds here. Be advised when delaying. If u use a short delay, the server might not capture data because of Arduino transmitting new data too soon.
// Sleep
Serial.println("ESP8266 in sleep mode");
//delay(5000);
gettemperature(); // Read the sensor
// Connect to the server (your local server on intranet)
if (client.connect(server, 181)) {
client.print("GET /html/emoncms/input/post?"); // This PHP script that is run on the zeus Apache 2.0 server and that posts the data to the MySQL database called "domotics".
client.print("node=THesp04");
client.print("&");
client.print("fulljson={");
client.print("\"temperature\":"); // This is the temperature value to post to the database
client.print(temperature); // And this is what we did in the testing section above. We are making a GET request just like we would from our browser but now with live data from the sensor
client.print(",");
client.print("\"humidity\":");
client.print(humidity);
client.print("}");
client.print("&");
client.print("apikey=c815g52de81c97ee9405fcef9d10c0ed");
//client.println(" HTTP/1.1"); // Part of the GET request
client.println(" "); //
client.println("Connection: close"); // Part of the GET request telling the server that we are over transmitting the message
client.println(); // Empty line
client.stop(); // Closing connection to server
else {
// If Arduino can't connect to the server (your computer or web page)
Serial.println("--> connection failed\n");
void gettemperature() {
// Wait at least 2 seconds seconds between measurements.
// if the difference between the current time and last time you read
// the sensor is bigger than the interval you set, read the sensor
// Works better than delay for things happening elsewhere also
if(currentMillis - previousMillis >= interval) {
// save the last time you read the sensor
// Reading temperature for humidity takes about 250 milliseconds!
// Sensor readings may also be up to 2 seconds 'old' (it's a very slow sensor)
humidity = dht.readHumidity(); // Read humidity (percent)
temperature = dht.readTemperature(); // Read temperature as Fahrenheit
// Check if any reads failed and exit early (to try again).
if (isnan(humidity) || isnan(temperature)) {
return;
