SOLVED: ESP-12E: debug output only, no esptool.py connection
Posted: Sun Jan 06, 2019 6:26 pm
Hello everybody,
I've bought this esp-12e module (2 of them). Now I'm trying to establish USB connectivity to them.
I'm using a 3.3V USB-TTL converter and an external power supply 3.3V 0.9mA (with common ground with USB-to-TTL) that works like a charm with development boards including esptool.py operation and wifi transmission. I also verified that the converter with short-circuited 3.3V-VCC and RX-TX gives me back my input in Arduino IDE serial monitor.
My connections are like here: .
When using `miniterm.py /dev/ttyUSB0 74880`, I have something like:
or else, if pressing GPIO0 upon reboot:
But I do not get anything after the last `ets_main.c`, no new wi-fi networks around either. I do not get anything readable as well when using 9600, 57600, 115200 baud rates.
After disconnecting miniterm.py (and possibly replugging usb and power to esp) I'm trying to issue `esptool.py -p /dev/ttyUSB0 read_mac`, but to no avail:
Again, no baud rates help: 4800, 9600, 57600, 74880, 115200, 460800.
The result is quite confusing: I can read debug info, thus my connection works, I can read USB loopback thus my converter works, I can (again) read debug info, thus my board works (at least to some extent).
BTW, I replicated this wiring using a devboard and its pin header, and did not succeed as well, so I presume there is something wrong with my schematics. The dev board works great if I use its internal converter.
Does anyone see anything awfully stupid here that ruins the connection? I'm feeling like having read all different pieces of advice available on the Internet, and cannot find anything new helpful.
Thank you in advance.
ets Jan 8 2013,rst cause:2, boot mode:(3,0)
ets_main.c
ets Jan 8 2013,rst cause:2, boot mode:(1,6)
esptool.py v2.5.1
Serial port /dev/ttyUSB0
Connecting........_____....._____....._____....._____....._____....._____....._____
A fatal error occurred: Failed to connect to Espressif device: Timed out waiting for packet header
