Page 1 of 5
Issues using images.
PostPosted: Fri Jan 11, 2019 11:49 am
by pablopablo
Hey everybody,
First time posting :D
So I am working on a project using a Huzzah ESP8266 with Arduino IDE. Basically what I am trying to acheive is that when a user accesses wifi (selects SSID), a captive portal page will open. This CPP will contain either an image or .gif.
I have been loosely following YourSunny's project https://yoursunny.com/t/2017/freewifi/
However, although I can get the CPP up + working, the image appears as a broken link.
So, I tried something simpler and just tried to have a html page with an image in it, for this I followed this tutorial
https://circuits4you.com/2018/01/31/upl ... -web-page/
However, I'm still having the same problem.
I should also say that when I test the page before uploading, it works no problem.
Completely puzzled, any suggestions greatly appreciated!
Re: Issues using images.
PostPosted: Tue Jan 15, 2019 7:12 am
by pablopablo
Just giving this a bump but also to say that to say that
I have been reading A-Beginner's-Guide-to-the-ESP8266 http://www.esploradores.com/wp-content/ ... 8266-1.pdf
On Page 34 it states (Only use small files like text files or icons. There's not enough space for large photos or videos.)
I wonder now if this is the issue? The jpegs/png I have tried have all been under 1mb.
PostPosted: Tue Jan 15, 2019 7:13 am
by pablopablo
PostPosted: Tue Jan 15, 2019 10:57 pm
by Good Science For You
pablopablo wrote:Just giving this a bump but also to say that to say that
Because I have a website and can use that for images, all one needs is to publish the reference address of the images. If you have anyone you know with a website that you can upload the photos to, would allow larger images. Actually any size that will fit on a web page and as many as you want. You should limit them to 70% of "perfect" image to keep them smaller for faster loading. As a matter of fact all images load VERY fast this way.
Also, I found that using single lines of html code and sending that for each image allows a lot of manipulation of the images on the screen. Position by coding them.
If you want. I can upload them to one of my websites. And then you can address them in your code. Also there are places where you can get a really cheap website service.
