today started working with ESP-07. I clould make the blink demo working.
Now I wanted to add an OLED display (Waveshare OLED 128x128 pixel (SSD1327))
https://www.waveshare.com/wiki/1.5inch_OLED_Module
In Arduino IDE I used the "Hello world" demo of following library:
https://www.arduinolibraries.info/libraries/u8g2
From this library I uncommented following constructor:
U8X8_SSD1327_MIDAS_128X128_4W_SW_SPI u8x8(/* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);But now I have a problem, I do not really know how to wire the OLED display to my ESP-07.
The OLED display has follwing pins (Vcc and GND is obvious, so I did not mention them here):
- [li]DIN[/li]
[li]CLK[/li]
[li]CS[/li]
[li]DC[/li]
[li]RST[/li]
In the documentation for ESP07 I found following SPI GPIO pins:
- [li]SCK - GPIO14[/li]
[li]MISO - GPIO12[/li]
[li]MOSI - GPIO13[/li]
[li]CS - GPIO15[/li]
But I don't know what pin on OLED side to connect with what pin on ESP07 side.
Could someone explain it to me?
And what should I do with the RST pin of my OLED? There is no equivalent pin on ESP07 side.
I further have to set the correct pin numbers in the u8x8 constructor.
What ESP07 pin I have to enter in the constructor for:
- [li]clock[/li]
[li]data[/li]
[li]cs[/li]
[li]dc[/li]
[li]reset[/li]
The HelloWorld example has following setup-function:
void setup(void)
/* U8g2 Project: SSD1306 Test Board */
//pinMode(10, OUTPUT);
//pinMode(9, OUTPUT);
//digitalWrite(10, 0);
//digitalWrite(9, 0);
/* U8g2 Project: KS0108 Test Board */
//pinMode(16, OUTPUT);
//digitalWrite(16, 0);
u8x8.begin();
u8x8.setPowerSave(0);
How I have to change it to work with my OLED?
Thanks a lot...
