New to all this ESP stuff, trying to figure out what is the freaking difference between those 2 chips in the photos.
Let me try to explain.. The right one with the blue led can be flashed normally and works fine with Tasmota and ESPEasy, flash, and boom all good.
The bastard on the left I've tried to flash with every possible version of Tasmota and ESPEasy.. It simply doens't work.. The only way that I could access it was with minimal OTA version from ESPEasy, but then I can't upgrade from there. I also can't run AT commands using the COM or anything like that..
I've got 3 of each model and the same happen for every chip. I'm going crazy testing everything possible with no good results.
Flashing using esptool with linux.
Does anyone has any idea of what could be happening?
Thank you
