I started to experiment with the Wemos D1 in combination with a 0.96 OLED screen (SSD1306) a few days ago.
An easy "Hello world" as well as the "DrawLogo" example from the "ACROBOTIC SSD1306" library are working as expected.
I've installed the "Adafruit SSD1306" library as I'm planning to set up a weather station. Unfortunately the example is not running what means the OLED screen is black after uploading. The weather station example is not working properly as well (same behavior).
After several tests I've connected an UNO board and started the Adafruit example and it WORKED.
I attached some pictures and screenshots.
Can you please help?
Thank you!
Steeven
