>>> TIMEOUT during basic connection test for Arduino
PostPosted: Thu Mar 28, 2019 7:17 am
by AxelD
Hi! Configuration for ESP8266-module:
Version info: 1.2.0.0
SDK 1.5.4.1
Ai-Thinker
We're unable to initialize the module through the serial monitor in Arduino IDE. We have configured the module to communicate on 9600 Baud Rate, and we're using this source code:
#include <SoftwareSerial.h>
#include "WiFiEsp.h"
SoftwareSerial Serial1(6,7);
char ssid[] = "XXX"; //Our personal information
char pass[] = "YYY";
int status = WL_IDLE_STATUS;
Serial1.begin(9600);
WiFi.init(&Serial1);
if (WiFi.status() == WL_NO_SHIELD){
Serial.println("WiFi shield not present");
while(true);
while(status != WL_CONNECTED ) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
status=WiFi.begin(ssid,pass);
Serial.println("You're connected to the network");
printWifiStatus();
void printWifiStatus(){
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
Output is:
>>>TIMEOUT
>>>TIMEOUT
>>>TIMEOUT
Is it possible that our source code is incorrect? We're currently trying to connect to a Mobile Tethering network, perhaps that doesn't work either (seems to work just fine for some ppl on this forum, have tried iPhone and Android). Any suggestions for means of troubleshooting this further??
Best regards, AD
