I'm pretty familiar with with basic programming and have written a discord bot which runs on a raspberry pi written in python. This bot sends a single integer to adafruit io from 0-255 wehenver the discord server status changes; I'm looking to convert this integer to binary from the NodeMCU itself as it will contain a list of colored status lights to flash through.
I would prefer this to be in a function / method (not sure of the terminology used for lua) that takes the int as an argument and simply returns the binary.
I've tried some of the following:
function toBits(num,bits)
-- returns a table of bits, most significant first.
bits = bits or math.max(1, select(2, math.frexp(num)))
local t = {} -- will contain the bits
for b = bits, 1, -1 do
t[b] = math.fmod(num, 2)
num = math.floor((num - t[b]) / 2)
return t
endand:
function bits(num)
local t={}
while num>0 do
rest=num%2
table.insert(t,1,rest)
num=(num-rest)/2
end return table.concat(t)
endBut have not been able to get the syntax right using arduino IDE and this strange modified version of Lua or I believe % (modulo) also doesn't work in this modififed version and I'm unsure how to implement it through a library or elsewhere.
Any suggestions / advice is appreciated.
Thank you.
