I see it's wifi network name is Farylink_somenumber. I connect to it. It's IP is 192.168.4.1 and my PC gets 192.168.4.2. I use my browser on it - and get nothing. I port-scan it (all 64k port) - nothing. I scan the entire 192.168.4.0/24 network to see if it's using a second IP for configuration. I get nothing. One other small detail - the board seems to have a single LED, but it doesn't come on, not even when I have a wifi connection to it.
I bought 3 of these wifi relays, and each comes as 2 boards, one board is the relay and the other is the ESP8266 board. I've tried 2 of the ESP boards so far, and both behave as I've just described above. I've powered just the ESP8266 board by itself (I have lab power supply with plenty of current) so I know the power supply is fine (and used 3.3 volts).
I start digging and learn about this whole esp8266 world. I really didn't want to have to learn about this world. I thought this thing would work "out of the box" and do what I wanted - which was to control a dumb relay over a wifi connection.
So what I'm here to ask about is - why are these things sold with some sort of firmware that apparently does nothing? Is there anything known about the default functionality these boards have as shipped?
I suppose I now have to cobble together a programming IDE, suitable firmware, and serial interface just to make this thing work as advertised?
