How to disable wifiMulti if unsucessful attempt to connect?
Posted: Mon Apr 29, 2019 7:30 am
I am using the standard example of wifiMulti in a sketch in an ArduinoIDE environment on an ESP8266-01. What I have found is if the SSID credentials are entered wrong, or the device is taken to a new environment (ie, work), the sketch just hangs up in the while loop searching for a viable network.
I want to be able to break the loop and start a softAP in event of an unsuccessful connect to WAN. I can break the while loop, and start a softAP. However, while the softAP starts and I can see its SSID on my laptop, it is very slow to connect and does not support the webserver which is running on the ESP. (In other words, the laptop connects, but Chrome says I am not connected to the internet and shows file not found errors.)
As long as wifiMulti connects to a viable network, everything runs smoothly using the ESP in _AP_STA mode. Or, if I comment out setupWifi() and use only apWifi(), everything runs smoothly using the ESP in _AP mode. It is only when wifiMulti fails to connect that I get hung up.
What do I need to do to disable wifiMulti when I break the loop? It seems to be negatively interfering with the softAP ability to establish a connection for the webserver. Thank you.
Here are some of the code snippets:
In my globals:
This function is called from setup. It sets up wifiMulti.
This function is called from setup to set up the softAP. After wifiMulti is called.
My void Setup has these bits, among many others to start up the wifi and server.
In my globals:
#include <ESP8266WiFiMulti.h>
#include <ESP8266WebServer.h>
ESP8266WiFiMulti wifiMulti;
ESP8266WebServer server(80);
//set up all of the necessary variables
void setupWifi() {
// WiFi.mode(WIFI_AP_STA);
aptime = millis();
wifiMulti.addAP("SSID1","PW1");
wifiMulti.addAP("SSID2", "PW2");
wifiMulti.addAP("SSID3", "PW3");
wifiMulti.addAP("SSID4", PW4");
Serial.println("Connecting Wifi...");
while (wifiMulti.run() != WL_CONNECTED) {
if (millis()-aptime >= apdelay) {
Serial.println("Network Failed");
break;
Serial.println("");
Serial.println("Connected to SSID: ");
Serial.println(WiFi.SSID());
void apWifi () {
//Setup softAP to run befor WiFiMulti
Serial.print("Configuring access point...");
WiFi.softAP("Box", "a");
Serial.println(myIP);
Void Setup(){
//… lots of variables, etc.
setupWifi();
apWifi():
server.on("/setup", handleConfigureDevice);
server.on("/update",handleUpdate);
server.onNotFound(handleNotFound);
server.begin();
Serial.println("HTTP Server Started");
server.handleClient();
