I was programming my Adafruit HUZZAH Board (connected to Arduino to exchange with a MQTT server) and everything was working fine during several days until after a code uploaded on the HUZZAH, I didn't receive anything. I connected the FTDI cable to see the serial display and saw :
ets Jan 8 2013,rst cause:4, boot mode:(1,6)
wdt resetSince then all my tests have given me very inconsistent results, full of different exceptions and resets for various reasons.
I uploaded a old version of the code that was working before, with no success.
I tried several things with the sketch upload like tweaking Flash Mode, Flash size, Erase Flash, with no success.
I tried to flash the firmware like explained in this post (the terminal said everything went well), with no success.
I tried my codes with a new HUZZAH, with a new FTDI cable, with powered USB hub, with no success.
Then I tried to upload basic sketches like ESP8266 blink which seems to work (seems because one time not, but after a reupload it worked).
I tried the code given by Adafruit to connect the ESP to internet and I got various results:
* Simple HTTP get webclient test
const char* ssid = "***";
const char* password = "***";
const char* host = "wifitest.adafruit.com";
delay(100);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.print("Netmask: ");
Serial.println(WiFi.subnetMask());
Serial.print("Gateway: ");
Serial.println(WiFi.gatewayIP());
int value = 0;
delay(5000);
++value;
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
return;
// We now create a URI for the request
String url = "/testwifi/index.html";
Serial.println(url);
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
while(client.available()){
Serial.print(line);
}Here is an extract of the tests to give you an idea (I used Exception Decoder to translate the stack in the log):
Test 1
- Upload code
Get an exception during first connection
Manual reset
Get the same exception
Works fine endlessly
Disconnect / Reconnect, works fine endlessly even after manual resets
Connecting to Livebox-90B4
WiFi connected
IP address:
192.168.1.39
Netmask: 255.255.255.0
Gateway: 192.168.1.connecting to wifitest.adafruit.com
Requesting URL: /testwifi/index.html
Exception (0):
epc1=0x40229120 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3ffffb60 end: 3fffffd0 offset: 01a0
>>>stack>>>
Decoding stack results
0x4020a621: glue2esp_linkoutput at glue-esp/lwip-esp.c line 299
0x4020a976: new_linkoutput at glue-lwip/lwip-git.c line 259
0x4020ad0b: ethernet_output at netif/ethernet.c line 305
0x4020e89f: tcp_write at core/tcp_out.c line 563
0x40210b20: etharp_output_to_arp_index at core/ipv4/etharp.c line 768
0x40211e83: ip_chksum_pseudo at core/inet_chksum.c line 395
0x40203312: ClientContext::_write_some() at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/libraries/ESP8266WiFi/src/include/ClientContext.h line 448
0x40201edc: uart_write at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/uart.c line 333
0x40203788: HardwareSerial::write(unsigned char const*, unsigned int) at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/HardwareSerial.h line 159
0x4020377c: HardwareSerial::write(unsigned char const*, unsigned int) at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/HardwareSerial.h line 158
0x4020eec6: tcp_output at core/tcp_out.c line 1123
0x4020bb20: sys_timeout_LWIP2 at core/timeouts.c line 217
0x4010020c: _umm_free at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/umm_malloc/umm_malloc.c line 1295
0x401006ac: realloc at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/umm_malloc/umm_malloc.c line 1645
0x40203d53: String::changeBuffer(unsigned int) at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/WString.cpp line 156
0x401064ca: millis at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/core_esp8266_wiring.c line 183
0x40203f48: operator new(unsigned int) at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/abi.cpp line 34
0x402033b4: ClientContext::_write_from_source(DataSource*) at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/libraries/ESP8266WiFi/src/include/ClientContext.h line 404
0x40203465: WiFiClient::write(unsigned char const*, unsigned int) at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/libraries/ESP8266WiFi/src/include/ClientContext.h line 330
0x402043cd: Print::print(String const&) at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/Print.cpp line 118
0x402026ad: loop() at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/WString.h line 263
0x40203984: Print::println() at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/Print.cpp line 178
0x402040f8: loop_wrapper() at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/core_esp8266_main.cpp line 125
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(1,7)
ets Jan 8 2013,rst cause:4, boot mode:(1,7)
wdt reset
// Manual Reset
WiFi connected
IP address:
192.168.1.39
Gateway: 192.168.1.1
Exception (0):
epc1=0x40216a64 epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3ffffb20 end: 3fffffd0 offset: 01a0
>>>stack>>>
Same Stack that above
<<<stack<<<
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
WiFi connected
IP address:
192.168.1.39
HTTP/1.1 200 OK
Server: nginx/1.10.3 (Ubuntu)
Date: Wed, 31 Jul 2019 13:39:20 GMT
Content-Type: text/html
Content-Length: 70
Last-Modified: Thu, 16 May 2019 18:21:16 GMT
Connection: close
ETag: "5cddaa1c-46"
Accept-Ranges: bytes
This is a test of Adafruit WiFi!
If you can read this, its working :)
closing connection
HTTP/1.1 200 OK
Date: Wed, 31 Jul 2019 13:39:31 GMT
Content-Length: 70
Connection: close
ETag: "5cddaa1c-46"
closing connection
HTTP/1.1 200 OK
Date: Wed, 31 Jul 2019 13:39:41 GMT
Content-Length: 70
Connection: close
ETag: "5cddaa1c-46"
// Working endlessly from thereTest 2
- Upload code
Get a WDT reset
Manual reset
Get an exception with a new stack
Gets stuck
Manual reset
wdt reset
Exception (0):
ctx: sys
sp: 3fffeaa0 end: 3fffffb0 offset: 01a0
>>>stack>>>
0x40203959: Print::write(char const*) at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/Print.h line 60
0x40201fa5: uart_flush at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/uart.c line 376
0x40202102: uart_init at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/uart.c line 438
0x401004e8: malloc at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/umm_malloc/umm_malloc.c line 1668
0x40202274: uart_init at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/uart.c line 276
0x402021d2: uart_init at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/uart.c line 489
0x4020406c: esp_yield() at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/core_esp8266_main.cpp line 91
0x4020150f: delay at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/core_esp8266_wiring.c line 51
0x4020251c: setup() at /Users/Arthur/Documents/Arduino/HuzzahWifiTest/HuzzahWifiTest.ino line 18
<<<stack<<<
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
//Stuck, manual reset
WiFi connected
IP address:
192.168.1.39
HTTP/1.1 200 OK
Date: Wed, 31 Jul 2019 13:51:56 GMT
Content-Length: 70
Connection: close
ETag: "5cddaa1c-46"
closing connection
HTTP/1.1 200 OK
Date: Wed, 31 Jul 2019 13:52:07 GMT
Content-Length: 70
Connection: close
ETag: "5cddaa1c-46"
closing connection
// Working endlesslyTest 3
- Upload code
Works perfectly
Disconnect / reconnect : get a new exception during the first connexion
Disconnect / reconnect 3 times : works fine
WiFi connected
IP address:
192.168.1.39
Exception 9: LoadStoreAlignmentCause: Load or store to an unaligned address
PC: 0x40208428: _Bfree at ../../../.././newlib/libc/stdlib/mprec.c line 141
EXCVADDR: 0x20d0003d
ctx: cont
sp: 3ffffcf0 end: 3fffffd0 offset: 01a0
>>>stack>>>
0x40207949: _dtoa_r at ../../../.././newlib/libc/stdlib/dtoa.c line 858
<<<stack<<<
ets Jan 8 2013,rst cause:1, boot mode:(3,0)
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
WiFi connected
IP address:
192.168.1.39
HTTP/1.1 200 OK
Date: Wed, 31 Jul 2019 13:56:13 GMT
Content-Length: 70
Connection: close
ETag: "5cddaa1c-46"
closing connection
Exception (0):
epc1=0x40229120 epc2=0x00000000 epc3=0x00000000 excvaddr=0x20d0003d depc=0x00000000
ctx: cont
sp: 3ffffaa0 end: 3fffffd0 offset: 01a0
>>>stack>>>
0x40211d94: mem_malloc at core/mem.c line 136
0x4020ad14: ethernet_output at netif/ethernet.c line 305
0x40203441: WiFiClient::write(unsigned char const*, unsigned int) at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/libraries/ESP8266WiFi/src/WiFiClient.cpp line 177
0x40203428: WiFiClient::write(unsigned char const*, unsigned int) at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/libraries/ESP8266WiFi/src/WiFiClient.cpp line 176
0x40203d9f: String::reserve(unsigned int) at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/WString.cpp line 146
0x40203e97: String::concat(char const*, unsigned int) at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/WString.cpp line 288
0x4020408d: esp_schedule() at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/core_esp8266_main.cpp line 95
<<<stack<<<
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
WiFi connected
IP address:
192.168.1.39
Exception (0):
epc1=0x4020bd20 epc2=0x00000000 epc3=0x00000000 excvaddr=0x20d0003d depc=0x00000000
ctx: sys
sp: 3fffed10 end: 3fffffb0 offset: 01a0
>>>stack>>>
0x4020ada4: memp_malloc at core/memp.c line 404
0x4020bc5c: cyclic_timer at core/timeouts.c line 165
0x4020bc74: cyclic_timer at core/timeouts.c line 172
0x4020bd20: sys_check_timeouts at core/timeouts.c line 351
0x40202a1c: ESP8266WiFiSTAClass::status() at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/libraries/ESP8266WiFi/src/ESP8266WiFiSTA.cpp line 498
0x40202b99: ESP8266WiFiSTAClass::begin(char const*, char const*, int, unsigned char const*, bool) at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/libraries/ESP8266WiFi/src/ESP8266WiFiSTA.cpp line 178
0x40202b75: ESP8266WiFiSTAClass::begin(char const*, char const*, int, unsigned char const*, bool) at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/libraries/ESP8266WiFi/src/ESP8266WiFiSTA.cpp line 168
0x40203a6d: Print::printNumber(unsigned long, unsigned char) at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/Print.cpp line 260
0x40202615: loop() at /Users/Arthur/Documents/Arduino/HuzzahWifiTest/HuzzahWifiTest.ino line 44
0x402039f8: Print::println(Printable const&) at /Users/Arthur/Library/Arduino15/packages/esp8266/hardware/esp8266/2.4.2/cores/esp8266/Print.cpp line 238
0x402025bc: setup() at /Users/Arthur/Documents/Arduino/HuzzahWifiTest/HuzzahWifiTest.ino line 38
<<<stack<<<
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
WiFi connected
IP address:
192.168.1.39
HTTP/1.1 200 OK
Date: Wed, 31 Jul 2019 13:56:35 GMT
Content-Length: 70
Connection: close
ETag: "5cddaa1c-46"
closing connection
// Working endlesslyTest 4
- Upload code
Works perfectly
What really puzzles me is the inconsistence between the tests and the variety of exceptions I get ^^'
And when it comes to the my code, the results are worse. Most of the time I get a connexion with the MQTT server after 1 or 2 exceptions after the upload. And most of the time, disconnect / reconnect gives me endless stacks of errors and I'm forced to reupload the code. During my last test, even the reupload couldn't stop the endless stacks (try several times), I had to reupload another code then mine to make it works (for a short time)... So weird!
I don't know what to do anymore ^^'
Thanks for your time
