I have a number of sensors (Masters) taking readings at set intervals & they send the readings via ESP-Now to my Slave unit.
This all works perfectly, I can see it all happening via the serial monitor of my Slave unit.
Now I wish to send these readings up to Adafruit Io & ThingSpeak at the same time from my Slave unit but I have tried over & over in placing the Adafruit & ThingSpeak code in my sketch but it does nothing.
Here is my full Slave unit sketch, I have starred out personal details.
Testing ESP-Now
See https://espressif.com/en/products/software/esp-now/overview
ESP-Now enables fast lightwieght connectionless communication between ESP8266's.
So for example a remote sensor node could send a reading using ESP-Now in just a few
hundred milliseconds and deepSleep the rest of the time and so get increased battery
life compared to the node using a regular WiFi connection which could take 10 times
as long to connect to WiFi and send a sensor reading.
ESP-Now has the concept of controllers and slaves. AFAICT the controller is the remote
sensor node and the slave is the always on "gateway" node that listens for sensor node readings.
*** Note: to compile ESP-Now (with arduino/esp8266 release 2.3.0) need to edit
* ~/Library/Arduino15/packages/esp8266/hardware/esp8266/2.1.0/platform.txt
* Search "compiler.c.elf.libs", and append "-lespnow" at the end of the line.
* See: http://www.esp8266.com/viewtopic.php?p=44161#p44161
**** This skecth is the slave/gateway node ****
Ant Elder
License: Apache License v2
#include "ThingSpeak.h" //FOR THINGSPEAK
#include "AdafruitIO_WiFi.h" //FOR ADAFRUIT
unsigned long myChannelNumber = 842555; //FOR THINGSPEAK
const char * myWriteAPIKey = "******"; //FOR THINGSPEAK
extern "C" {
#include <espnow.h>
const char* ssid = "******";
const char* password = "******";
#define AIO_USERNAME "******" //FOR ADAFRUIT
#define AIO_KEY "******" //FOR ADAFRUIT
AdafruitIO_WiFi io(AIO_USERNAME, AIO_KEY, ssid, password); //FOR ADAFRUIT
AdafruitIO_Feed *BedroomTempFeed = io.feed("bedroom"); //FOR ADAFRUIT
#define WIFI_CHANNEL 1
// keep in sync with sensor struct
struct SENSOR_DATA_DHT22 {
String name_dht22;
float temp_dht22;
int hum_dht22;
float t_dht22;
struct SENSOR_DATA_DS18B20_1 {
String name_ds18b20_1;
float temp_ds18b20_1;
float t_ds18b20_1;
struct SENSOR_DATA_DS18B20_2 {
String name_ds18b20_2;
float temp_ds18b20_2;
float t_ds18b20_2;
WiFiClient client; //FOR THINGSPEAK
Serial.begin(115200); Serial.println();
ThingSpeak.begin(client); //FOR THINGSPEAK
initWifi();
io.connect(); //FOR ADAFRUIT
if (esp_now_init()!=0) {
Serial.println("*** ESP_Now init failed");
ESP.restart();
Serial.print("This node AP mac: "); Serial.print(WiFi.softAPmacAddress());
Serial.print(", STA mac: "); Serial.println(WiFi.macAddress());
// Note: When ESP8266 is in soft-AP+station mode, this will communicate through station interface
// if it is in slave role, and communicate through soft-AP interface if it is in controller role,
// so you need to make sure the remote nodes use the correct MAC address being used by this gateway.
esp_now_set_self_role(ESP_NOW_ROLE_SLAVE);
esp_now_register_recv_cb([](uint8_t *mac, uint8_t *data_dht22, uint8_t len) {
Serial.print("recv_cb, from mac: ");
char macString[50] = {0};
sprintf(macString, "%02X:%02X:%02X:%02X:%02X:%02X", mac[0], mac[1], mac[2], mac[3], mac[4], mac[5]);
Serial.print(macString);
getReading_DHT22(data_dht22, len);
esp_now_register_recv_cb([](uint8_t *mac, uint8_t *data_ds18b20_1, uint8_t len) {
getReading_DS18B20_1(data_ds18b20_1, len);
esp_now_register_recv_cb([](uint8_t *mac, uint8_t *data_ds18b20_2, uint8_t len) {
getReading_DS18B20_2(data_ds18b20_2, len);
void loop() {}
void getReading_DHT22(uint8_t *data_dht22, uint8_t len) {
SENSOR_DATA_DHT22 tmp_dht22;
memcpy(&tmp_dht22, data_dht22, sizeof(tmp_dht22));
Serial.print(", parsed data, t="); Serial.println(tmp_dht22.t_dht22);
Serial.print(tmp_dht22.name_dht22); Serial.print(" Temperature = "); Serial.print(tmp_dht22.temp_dht22); Serial.println("\u2103");
Serial.print(tmp_dht22.name_dht22); Serial.print(" Humidity = "); Serial.print(tmp_dht22.hum_dht22); Serial.println("%");
void getReading_DS18B20_1(uint8_t *data_ds18b20_1, uint8_t len) {
SENSOR_DATA_DS18B20_1 tmp_ds18b20_1;
memcpy(&tmp_ds18b20_1, data_ds18b20_1, sizeof(tmp_ds18b20_1));
io.run(); //FOR ADAFRUIT
BedroomTempFeed->save(tmp_ds18b20_1.temp_ds18b20_1); //FOR ADAFRUIT
ThingSpeak.writeField(myChannelNumber, 1, tmp_ds18b20_1.temp_ds18b20_1, myWriteAPIKey); //FOR THINGSPEAK
Serial.print(", parsed data, t="); Serial.println(tmp_ds18b20_1.t_ds18b20_1);
Serial.print(tmp_ds18b20_1.name_ds18b20_1); Serial.print(" Temperature = "); Serial.print(tmp_ds18b20_1.temp_ds18b20_1); Serial.println("\u2103");
void getReading_DS18B20_2(uint8_t *data_ds18b20_2, uint8_t len) {
SENSOR_DATA_DS18B20_2 tmp_ds18b20_2;
memcpy(&tmp_ds18b20_2, data_ds18b20_2, sizeof(tmp_ds18b20_2));
Serial.print(", parsed data, t="); Serial.println(tmp_ds18b20_2.t_ds18b20_2);
Serial.print(tmp_ds18b20_2.name_ds18b20_2); Serial.print(" Temperature = "); Serial.print(tmp_ds18b20_2.temp_ds18b20_2); Serial.println("\u2103");
void initWifi() {
WiFi.mode(WIFI_AP_STA);
WiFi.softAP("MyGateway", "12345678", WIFI_CHANNEL, 1);
Serial.print("Connecting to "); Serial.print(ssid);
if (strcmp (WiFi.SSID().c_str(), ssid) != 0) {
WiFi.begin(ssid, password);
int retries = 20; // 10 seconds
while ((WiFi.status() != WL_CONNECTED) && (retries-- > 0)) {
Serial.print(".");
Serial.println("");
if (retries < 1) {
Serial.print("*** WiFi connection failed");
ESP.restart();
Serial.print("WiFi connected, IP address: "); Serial.println(WiFi.localIP());
}Any help would be appreciated.
Kirk
