I'm trying to get an old project back up and I stumbled on to this error.
Udp-class is renamed to EthernetUdpI'm not sure what to do, add new library or change the udp?
#if defined(ESP8266)
#include <ESP8266WiFi.h> // Include the Wi-Fi library
#else
#include <WiFi.h>
#endif
#include <WiFiUdp.h> // UDP library
#include <OSCMessage.h> // OSC library
#include <Wire.h>
const char* ssid = "df"; // The SSID (name) of the Wi-Fi network you want to connect to
const char* password = "df"; // The password of the Wi-Fi network
Serial.begin(115200); // Start the Serial communication to send messages to the computer
delay(10);
Serial.println('\n');
WiFi.begin(ssid, password); // Connect to the network
Serial.print(ssid); Serial.println(" ...");
int i = 0;
while (WiFi.status() != WL_CONNECTED) { // Wait for the Wi-Fi to connect
delay(1000);
Serial.print(++i); Serial.print(' ');
Serial.println("Connection established!");
Serial.print("IP address:\t");
Serial.println(WiFi.localIP()); // Send the IP address of the ESP8266 to the computer
Serial.println("Starting UDP");
Udp.begin(localPort);
Serial.print("Local port: ");
#ifdef ESP32
Serial.println(localPort);
#else
Serial.println(Udp.localPort());
#endif
OSCMessage msg("/trigger/prophet");
msg.add("hello, osc.");
Udp.beginPacket(outIp, outPort);
msg.send(Udp);
Udp.endPacket();
msg.empty();
