By MAWMN
#86053 While trying to write my own simple custom udp client library, I am having some troubles getting it to work.
[see Code parts UDPClient2.cpp and UDPClient2.h as well as a test application ESP8266_UDPClient2.ino]
Is there anyone who can point me in the right direction ?
Problems & Questions :
    No data is being sent to the PC, because in the Library the _socketIsOpen keeps being reported as FALSE, while when having received Data the _socketIsOpen should be reported as being TRUE
    In the library defined debug messages don't work either
    I am wondering why I have to declare "WiFiUDP clUDP" to be able to use "UDPClient2 myClient(clUDP)"
thanks..
UDPClient2.cpp
Code: Select all#include "Arduino.h"
#include "UDPClient2.h"
// Uncomment to enable printing out nice debug messages.
#define DEBUG_UPDClientLib           // UDP Library produces Debug info on Serial Monitor..
 UDPClient2::UDPClient2(UDP& udp) {
   this->_udp            = &udp;
void UDPClient2::begin() {
  this->_udp->begin(this->_port);   // = UDP_DEFAULT_LOCAL_PORT
  this->_udpSetup = true;
  #ifdef DEBUG_UDPClientLib
    Serial.print("UDP-Port        : ");
    Serial.println(this->_port);
   Serial.print("UDPSetup        : ");
    Serial.println(this->_udpSetup);
   Serial.flush();
  #endif
void UDPClient2::begin(int port) {   // = ANY GIVEN PORT
  this->_port = port;
   Serial.flush();
  #endif
int UDPClient2::receive() {
  //   if there's data available, read the packet
  int packetSize = this->_udp->parsePacket();
  if (packetSize)
    // Receive ANY packet and Remember the open Socket Params
    this->_remoteIp = this->_udp->remoteIP();
    this->_remotePort = this->_udp->remotePort();
    // Read the packet into receiveBufffer
    int len = this->_udp->read(this->_receiveBuffer, sizeof(this->_receiveBuffer));
    if (len > 0) this->_receiveBuffer[len] = 0;   // close the received data in the buffer
    this->_socketIsOpen = true;
     Serial.println("*** UDP-Data Received ***");
     Serial.print("UDP-Data Size   : ");
      Serial.println(packetSize);
     Serial.print("from RemoteIP   : ");
      Serial.println(this->_remoteIp);
     Serial.print("in RemotePort   : ");
      Serial.println(this->_remotePort);
     Serial.print("SocketState     : ");
      Serial.println(this->_socketIsOpen);
      Serial.flush();
    #endif
  return packetSize;
String UDPClient2::getReceiveBuffer() {
  String rtnStr = this->_receiveBuffer;   // Convert Array to String
   Serial.print("UDP-Data String : ");
    Serial.println(rtnStr);
   Serial.flush();
  #endif
  return rtnStr;
bool UDPClient2::send(String toSend) {
   Serial.println("*** UDP-Data Send ***");
    Serial.println(toSend);
   Serial.flush();
  #endif
  if (this->_socketIsOpen) {
    // Send ANY Packet if the Socket is open
    memset(this->_sendBuffer, 0, sizeof(this->_sendBuffer));  // fill the sendBuffer with 0
//    strcpy(this->_sendBuffer, toSend.c_str());                // Copy the chars to_send array to the sendBuffer
    strcpy((char *)this->_sendBuffer, toSend.c_str());          // Copy the bytes to_send array to the sendBuffer
     Serial.print("Sendbuffer      : ");
      Serial.println(this->_sendBuffer);
     Serial.print("Sendbuffer Size : ");
      Serial.println(sizeof(this->_sendBuffer));
     Serial.print("to RemoteIP     : ");
     Serial.flush();
    #endif
    // Send the Packet, to the IP address and port that sent us these packets before
    this->_udp->beginPacket(this->_remoteIp, this->_remotePort);
    //this->_udp->write((uint8_t) *this->_sendBuffer );             // Does NOT Work as in NTPClient2, Sendbuffer is of type char ipv byte
    this->_udp->write(this->_sendBuffer, sizeof(this->_sendBuffer)); // Works as in NTPClient2, Sendbuffer is of type byte ipv char
    this->_udp->endPacket();
    return true;
  } else return false;
bool UDPClient2::getIsSocketOpen() {
    // No packet has been received in 70 seconds, restart the UdpClient
    this->_socketIsOpen = false;
    // Stop & Restart the Udp client2 connection ,
    //   to clear the remebered remoteIp and remotePort
    // Because of reset WDT cause:2, boot mode:(3,6), insert delay(0)
    this->_udp->stop();
    delay(0);
    this->_udp->begin(this->_port);         // = LocalPort
    delay(0);
     Serial.println("*** Socket has been Closed ***");
     Serial.print("Port Restart    : ");
     Serial.flush();
    #endif
  return this->_socketIsOpen;
bool UDPClient2::update() {
  if ((millis() - this->_lastUpdate >= this->_updateInterval)     // Update after _updateInterval
    || this->_lastUpdate == 0) {                                  // Update if there was no update yet.
    if (!this->_udpSetup) this->begin(this->_port);               // setup the UDP client if needed
    return this->getIsSocketOpen();
  } else return true;
IPAddress UDPClient2::getRemoteIp() {
   Serial.print("getRemoteIP     : ");
   Serial.flush();
  #endif
  return this->_remoteIp;
uint16_t UDPClient2::getLocalPort() {
   Serial.print("getLocalPort    : ");
   Serial.flush();
  #endif
  return this->_port;
uint16_t UDPClient2::getRemotePort() {
   Serial.print("getRemotePort   : ");
   Serial.flush();
  #endif
  return this->_remotePort;
void UDPClient2::setUpdateInterval(unsigned int updateInterval) {
  this->_updateInterval = updateInterval;
   Serial.print("setUpdateInterval: ");
    Serial.println(this->_updateInterval);
   Serial.flush();
  #endif
void UDPClient2::end() {
  this->_udp->stop();
  this->_udpSetup = false;
   Serial.println("*** Close UDP Connection ***");
   Serial.flush();
  #endif
UDPClient2.h
Code: Select all#ifndef UDPClient2_h
#define UDPClient2_h
#pragma once
#include <WiFiUdp.h>
#define UDP_DEFAULT_LOCAL_PORT 2101
#define UDP_DEFAULT_BUFFSIZE 255
class UDPClient2 {
  private:
    UDP*          _udp;
    bool          _udpSetup       = false;
    int           _port           = UDP_DEFAULT_LOCAL_PORT;
    IPAddress     _remoteIp       = '\0';
    uint16_t      _remotePort     = 0;
    char          _receiveBuffer[UDP_DEFAULT_BUFFSIZE];      // Buffer to hold incoming Udp-packet
//    char          _sendBuffer[255];       // A Custom char string to send back to the PC
    byte          _sendBuffer[UDP_DEFAULT_BUFFSIZE];         // A Custom byte string to send back to the PC
    bool          _socketIsOpen   = false;
    unsigned int  _updateInterval = 60000;  // In ms
    unsigned long _lastUpdate     = 0;      // In ms
  public:
    UDPClient2(UDP& udp);
    //  * Starts the underlying UDP client with the default local port
    void begin();
     * Starts the underlying UDP client with the specified local port
    void begin(int port);
     * This should be called in the main loop of your application.
     * By default an update from the UDP Server is done automatically.
     * @return #num of characters received on success, 0 on failure
     int receive();
     * @return The Receivebuffer contents as a String
    String getReceiveBuffer();
     * @return The result if the message has been sent
    bool send(String toSend);
     * @return The Status of the Current UDP Socket, OPEN = true, CLOSED = false
    bool getIsSocketOpen();
     * @return The RemoteIP for the UDP Socket
    IPAddress getRemoteIp();
     * @return The LocalPort for the UDP Socket
    uint16_t getLocalPort();
     * @return The RemotePort for the UDP Socket
    uint16_t getRemotePort();
     * By default an update from the UDP Server is only
     * made every 60 seconds.
     * @return true on success, false on failure
     bool update();
     * Sets the timer update Interval
    void setUpdateInterval(unsigned int interval);
     * Stops the underlying UDP client
    void end();
#endif
Code: Select all// Orgineel - 11-03-2020   ESP8266_UDPClient2.ino
#include <ESP8266WiFi.h>                            // ESP8266 WiFi
#include <WiFiUdp.h>                                // WiFi
#include <ESP8266WebServer.h>     // tbv WiFiManager
#include <DNSServer.h>            // tbv WiFiManager
#include <WiFiManager.h>          // tbv WiFiManager
#include <UDPClient2.h>                             // tbv Simple Custom UDPClient for Wemos Device specific application
#define DEBUG_UPDClientLib     // UDP Library produces Debug info on Serial Monitor.. (NOT Working ??)
// #define UDPCLIENT_DEBUG
// Define where debug output will be printed.
#define UDPCLIENT_PRINTER Serial
// Setup DBG_UDP printing MACRO
#ifdef UDPCLIENT_DEBUG
  #define DBG_UDP_PRINT(...) { UDPCLIENT_PRINTER.print(__VA_ARGS__); }
  #define DBG_UDP_PRINTLN(...) { UDPCLIENT_PRINTER.println(__VA_ARGS__); }
#else
  #define DBG_UDP_PRINT(...) {}
  #define DBG_UDP_PRINTLN(...) {}
#endif
// tbv testen LIBRARY CODE UDPClient2 (myClient)
WiFiUDP clUDP;                                    // Start the underlying UDP Library
UDPClient2  myClient(clUDP);                      // Start the Custom Udp Client (LIBRARY) functionality
int UdpLocPort                        = 2101;     // local port to listen on for Udp messages send by the PC
unsigned long alivePeviousSendTime    = millis(); // aliveSendTime when the last alive packet was send to the PC
const long    aliveSendtimeoutTime    = 60;       // Define timeout time to send an alive packet to the PC in sec.
unsigned long lastReceivedTime        = millis(); // timestamp of the last received packet from the PC
unsigned long lastReceivedtimeoutTime = 70;       // Define min. timeout of the last received packet from the PC in sec.
  /***** Serial Setup *****/
  /***** WiFiManager Setup *****/
  // WiFiManager Initialisation
  WiFiManager wifiManager;
  // WiFiManager setDebugInfo (true or false)
  wifiManager.setDebugOutput(false);
  // Reset WiFiManager's saved Setting from Eeprom
  //   comment out after config is done, Parameter Reset can Now be done by WebPage
  //wifiManager.resetSettings();
  // Set TimeOut until the Configuration Portal gets turned OFF (in Sec.)
  wifiManager.setTimeout(120UL);
  // Sets the minimum Signal Quality, will NOT show sign ON networks below the set value,
  //   default is set to 8% (so uou will see a lot of networks !!!)
  wifiManager.setMinimumSignalQuality(30);  // Min. RSSI Quality = 30%
  // Disable sleep, can improve Access Point stability
  WiFi.setSleepMode(WIFI_NONE_SLEEP);
  // Start an AccessPoint with the specified name here (mna_AP_Test_Manager),
  //   and goes into a blocking loop awaiting configuration at IP Address 192.168.4.1
  //   Serial.println("Failed to connect and hit TimeOut");
  //   delay(3000);
  //   // Reset and Try again
  //   ESP.reset();
  //   delay(5000);
  // OR With Autoconnect !!!
  //   fetches SSID and Password from Eeprom and tries to Connect,
  //   if it does NOT Connect it starts an AccessPoint with the specified name,
  //   and goes into a blocking loop awaiting configuration.
  // OR With Autoconnect & Reset!!!
  //   and goes into a blocking loop awaiting (New) configuration.
  if (!wifiManager.autoConnect("mna_AP_Test_Manager", "")) {
    Serial.flush();
    delay(3000);
    //   the complete Program will be Restarted Now...(as if it was Powered UP again)
    ESP.reset();
    delay(5000);
  /***** Start the Custom UDP Client (myClient) @port 2101 *****/
  myClient.begin();                       // Start the Custom Client to listen @port 2101
  /***** Application Startup *****/
  Serial.println("***** mna_AP_Test_Manager - Board Startup Message  *****");
  Serial.print("Connected to     : ");
  Serial.println(WiFi.SSID());
  Serial.flush();
  Serial.print("IP gateway       : ");
  Serial.println(WiFi.gatewayIP());
  Serial.print("IP subnet        : ");
  Serial.println(WiFi.subnetMask());
  Serial.print("IP address       : ");
  Serial.print("UdpLocalPort     : ");
  Serial.println(myClient.getLocalPort());
  Serial.flush();
  Serial.println("----------------------------------------------");
  Serial.println("Start Receiving & Sending the UDP Data");
void UdpClientDebugInfo(String InpStr, int Richting)    // Richting 1 = Send To PC, 2 = Received from PC
    // tbv Debug
    if (Richting == 1) {
      UDPCLIENT_PRINTER.print("Send to PC       : ");
      UDPCLIENT_PRINTER.print(InpStr);                  // Packet contents
    } else if (Richting == 2) {
      UDPCLIENT_PRINTER.print("Received from PC : ");
    UDPCLIENT_PRINTER.print(" (");
    UDPCLIENT_PRINTER.print(InpStr.length());           // Packet Length
    UDPCLIENT_PRINTER.print(")\t[locIP (Dev) ");
    UDPCLIENT_PRINTER.print(WiFi.localIP());            // Local IP (Dev)
    UDPCLIENT_PRINTER.print(" : remIP (PC) ");
    UDPCLIENT_PRINTER.print(myClient.getRemoteIp());    // Remote IP (PC)
    UDPCLIENT_PRINTER.print(" : DevLisPort ");
    UDPCLIENT_PRINTER.print(myClient.getLocalPort());   // Device Listener Port
    UDPCLIENT_PRINTER.print(" : DevOutPort ");
    UDPCLIENT_PRINTER.print(myClient.getRemotePort());  // Device Output via Port
    UDPCLIENT_PRINTER.println("]");
  #endif
bool SendPacket(String &toSend) {
  Serial.println(myClient.getIsSocketOpen());
  if (myClient.getIsSocketOpen()) {
    Serial.print("Data to Send : ");
    myClient.send(toSend);
    return true;
void ReceiveUdp() {
  // Try to Receive UDP-Packets
  int packSize =  myClient.receive();
  if (packSize > 0)
    yield();  // Feed the WDT as the text output can take a while to print.
    // Analize the Received contents
    String recvStr = myClient.getReceiveBuffer();   // Convert Array to String
      // tbv Debug
      UdpClientDebugInfo(recvStr, 2);
    #endif
    Serial.flush();
    // Analize received data, do we need to reply ?
    String WhatToSend = "";
    if (recvStr == "PcAlive") {
      WhatToSend = "DevACK";
    } else {
      // what else to do ??
    // Send the Reply
    if (WhatToSend != "") {
      SendPacket(WhatToSend);     // Blind send a packet to the PC, NO Control if the socket realy is open
        // tbv Debug
        UdpClientDebugInfo(WhatToSend, 1);
      #endif
      Serial.flush();
void SendDeviceAlive() {
  // Send a (fixed) packet to the PC in an fixed time interval (change this for other situations..)
  if ((millis() - alivePeviousSendTime) > (aliveSendtimeoutTime * 1000)) {
    String WhatToSend = "DevAlive";
    if (SendPacket(WhatToSend)) {          // Control if the socket realy is open
        // tbv Debug
      #endif
      Serial.flush();
    } else {
        // tbv Debug
        UDPCLIENT_PRINTER.println("There is NO open Socket (anyMore, AutoClosed) to send anything to...");
      #endif
      Serial.flush();
  // Your main code here, to run repeatedly & test the Library:
  ReceiveUdp();
  SendDeviceAlive();
  myClient.update();
