[SOLVED] No WiFi networks available after deep sleep
Posted: Sat May 23, 2020 8:05 am
Hello,
I have an ESP12F with DHT22 sensor that publishes to MQTT over WiFi, then goes to deep sleep for 10 minutes, and tries again. I am using the Arduino IDE.
I've had really inconsistent behaviour where sometimes it works fine, sometimes it gets stuck in a WiFi blackhole: on boot it connects fine, but after deep sleep, it cannot find any networks at all.
I'm trying to minimise battery power so use
at the start of the code, and when I know I need to use WiFi use:
This is the output with serial debugging:
The schematic is: (I get the same error powering off USB so it's not a current draw issue from the MCP1700).
The full code is here.
Any help appreciated - I've been trying different things over the last couple of weeks and can't seem to shake this - hopefully something newbie-related that I've missed.
A
WiFi.mode(WIFI_OFF);
WiFi.forceSleepBegin();
delay(1);
WiFi.forceSleepWake();
delay(1);
WiFi.persistent(false);
// Bring up the WiFi connection
WiFi.mode(WIFI_STA);
// Static IP assignment
WiFi.config(ip,gateway,subnet);
WiFi.hostname(wifi_hostname);
WiFi.begin(wifi_ssid, wifi_password);
int count = 0;
if (count > 50) { // 5 seconds
if (debug) {
Serial.println("WiFi connection timeout, dropping back into deep sleep");
Serial.println(WiFi.status());
int n = WiFi.scanNetworks(false, true);
Serial.print(n);
Serial.println(" WiFi network(s) detected");
String ssid;
uint8_t encryptionType;
int32_t RSSI;
uint8_t* BSSID;
int32_t channel;
bool isHidden;
for (int i = 0; i < n; i++)
WiFi.getNetworkInfo(i, ssid, encryptionType, RSSI, BSSID, channel, isHidden);
Serial.printf("%d: %s, Ch:%d (%ddBm) %s %s\n", i + 1, ssid.c_str(), channel, RSSI, encryptionType == ENC_TYPE_NONE ? "open" : "", isHidden ? "hidden" : "");
ESP.deepSleep(polling_us, WAKE_RF_DISABLED ); // in uS
delay(100);
if (debug) Serial.print(".");
count++;
13:50:36.068 -> Connecting to SSID
13:50:36.172 -> fpm close 3
13:50:36.172 -> mode : sta(dc:4f:22:1d:a3:24)
13:50:36.172 -> add if0
13:50:36.279 -> ............................scandone
13:50:39.026 -> no SSID found, reconnect after 1s
13:50:39.093 -> .reconnect
13:50:39.199 -> ......................WiFi connection timeout, dropping back into deep sleep
13:50:41.293 -> 6
13:50:41.293 -> scandone
13:50:43.490 -> scandone
13:50:43.490 -> 0 WiFi network(s) detected
13:50:43.490 -> del if0
13:50:43.490 -> usl
13:50:43.557 -> enter deep sleep
A
