And today I tried to turn on the NodeMCU and I get that script. "No GPS detected: check wiring."
#include <TinyGPS++.h>
#include <SoftwareSerial.h>
#define BLYNK_PRINT Serial
#include <BlynkSimpleEsp8266.h>
static const int RXPin = 4, TXPin = 5 ; // GPIO 4=D2(conneect Tx of GPS) and GPIO 5=D1(Connect Rx of GPS
static const uint32_t GPSBaud = 9600; //if Baud rate 9600 didn't work in your case then use 4800
TinyGPSPlus gps; // The TinyGPS++ object
WidgetMap myMap(V0); // V0 for virtual pin of Map Widget
SoftwareSerial ss(RXPin, TXPin); // The serial connection to the GPS device
BlynkTimer timer;
float spd; //Variable to store the speed
float sats;
String bearing; //Variable to store orientation or direction of GPS
char auth[] = "----"; //Your Project authentication key
char ssid[] = "tt"; // Name of your network (HotSpot or Router name)
char pass[] = "ayyyyylmao"; // Corresponding Password
//unsigned int move_index; // moving index, to be used later
unsigned int move_index = 1; // fixed location for now
void setup()
ss.begin(GPSBaud);
Blynk.begin(auth, ssid, pass);
timer.setInterval(5000L, checkGPS); // every 5s check if GPS is connected, only really needs to be done once
void checkGPS(){
if (gps.charsProcessed() < 10)
Serial.println(F("No GPS detected: check wiring."));
Blynk.virtualWrite(V4, "GPS ERROR"); // Value Display widget on V4 if GPS not detected
void loop()
while (ss.available() > 0)
// sketch displays information every time a new sentence is correctly encoded.
if (gps.encode(ss.read()))
displayInfo();
Blynk.run();
timer.run();
void displayInfo()
if (gps.location.isValid() )
float latitude = (gps.location.lat()); //Storing the Lat. and Lon.
float longitude = (gps.location.lng());
Serial.print("LAT: ");
Serial.println(latitude, 6); // float to x decimal places
Serial.print("LONG: ");
Serial.println(longitude, 6);
Blynk.virtualWrite(V1, String(latitude, 6));
Blynk.virtualWrite(V2, String(longitude, 6));
myMap.location(move_index, latitude, longitude, "GPS_Location");
spd = gps.speed.kmph(); //get speed
Blynk.virtualWrite(V3, spd);
sats = gps.satellites.value(); //get number of satellites
Blynk.virtualWrite(V4, sats);
bearing = TinyGPSPlus::cardinal(gps.course.value()); // get the direction
Blynk.virtualWrite(V5, bearing);
}I didn't changed anything, it just stop working for some reason.
my connections between GPS module to NodeMCU are :-
VCC ~ 3V
RX ~ D1
TX ~ D2
GND ~ GND
Previously whenever I plugged in the cable, both nodemcu and GPS module blink at least once. after successfully connected it will keep on blinking. but now only nodemcu seems responding with the blinking.
GPS module does not respond at all. no blink no nothing.
Help me figure out this one
