I already have a link that if I open(ifttt), it sends an email but I have trouble with making the esp8266 opening the link.
Can someone help me what do I need in the if loop or am I doing it completely wrong?
Thanks for any help.
#include <DallasTemperature.h>
#include <OneWire.h>
#include <ThingSpeak.h>
#define ONE_WIRE_BUS 5
#define TEMPERATURE_PRECISION 10
unsigned long myChannelNumber = 1;
const char * myWriteAPIKey="xxxxx";
const char* ssid= "xxxxx";
const char* password= "xxxxx";
const char* host = "maker.ifttt.com";
int fieldStart = 1;
int status = WL_IDLE_STATUS;
WiFiClient client;
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
int numberOfDevices;
DeviceAddress tempDeviceAddress;
delay(100);
pinMode(A0,INPUT);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");}
Serial.println("");
ThingSpeak.begin(client);
sensors.begin();
numberOfDevices = sensors.getDeviceCount();
Serial.print("Locating devices...");
Serial.print("Found ");
Serial.print(numberOfDevices, DEC);
Serial.println(" devices.");
Serial.print("Parasite power is: ");
if (sensors.isParasitePowerMode()) Serial.println("ON");
else Serial.println("OFF");
for(int i=0;i<numberOfDevices; i++)
{if(sensors.getAddress(tempDeviceAddress, i)){
Serial.print("Found device ");
Serial.print(i, DEC);
Serial.print(" with address: ");
printAddress(tempDeviceAddress);
Serial.print("Setting resolution to ");
Serial.println(TEMPERATURE_PRECISION, DEC);
sensors.setResolution(tempDeviceAddress, TEMPERATURE_PRECISION);
Serial.print("Resolution actually set to: ");
Serial.print(sensors.getResolution(tempDeviceAddress), DEC);
Serial.println(); }else{
Serial.print("Found ghost device at ");
Serial.print(" but could not detect address. Check power and cabling");}}}
void printAddress(DeviceAddress deviceAddress)
{for (uint8_t i = 0; i < 8; i++){
if (deviceAddress[i] < 16) Serial.print("0");
Serial.print(deviceAddress[i], HEX);}}
sensors.requestTemperatures();
for (int i=0; i<=(numberOfDevices - 1); i++){
float temp=sensors.getTempCByIndex(i);
ThingSpeak.setField(i+fieldStart,temp);
Serial.println("Sensor #:");
Serial.println(i);
Serial.println("Temperature:");
Serial.println(temp);
ThingSpeak.writeFields(myChannelNumber, myWriteAPIKey);
Serial.println("Data sent to ThinkSpeak");
if(temp>28){
delay(15000);}}
