By Gokhan E
#87750 Hi i have a code like this. I try to control step motor with HA. I am sending step values via mqtt. So far no problem.
But if i dont use "disable watchdog" then i get crash around step no 100 and if i use watchdog i get error around step no 1300.
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x4010f000, len 3456, room 16
tail 0
chksum 0x84
csum 0x84
va5432625
~ld
#include <PubSubClient.h>
#include <AccelStepper.h>
#define Motor1_Dir 5
#define Motor1_Step 4
const char* ssid = "xxx";
const char* password = "xxx";
const char* mqtt_server = "xxx";
const char* mqttUser = "xxx";
const char* mqttPassword = "xxx";
int value;
bool flag1;
AccelStepper stepper(1, Motor1_Step, Motor1_Dir);
WiFiClient espClient;
PubSubClient client(espClient);
void setup_wifi()
  delay(10);
  Serial.println(ssid);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    Serial.print(".");
  randomSeed(micros());
  Serial.println("");
void callback(char* topic, byte* payload, unsigned int length)
  Serial.print("Message arrived [");
  Serial.print(topic);
  Serial.print("] ");
value = 0;
  int tensValue = 1;
  for (int i = length - 1; i >=0; i--) // iterate backwards
    value += (payload[i] - '0') * tensValue ;
    tensValue = tensValue * 10;
  flag1 = true;
//  for (int i = 0; i < length; i++)
//   Serial.print((char)payload[i]);
 // value = (char)payload [length -1];
 //   flag1 = true;
//  Serial.println();
//  Serial.print("Mesaj Geldi");
void reconnect()
  while (!client.connected())
    Serial.print("Attempting MQTT connection...");
    if (client.connect("alkan"))
      Serial.println("connected");
      client.subscribe("Alkan/perde");
      Serial.print("failed, rc=");
      Serial.print(client.state());
      Serial.println(" try again in 3 seconds");
      delay(3000);
void setup()
  setup_wifi();
  client.setServer(mqtt_server, 1883);
  client.setCallback(callback);
  stepper.setMaxSpeed(200);
  stepper.setAcceleration(100);
//  stepper.setSpeed(200);
void loop()
  if (!client.connected())
    reconnect();
  client.loop();
     if( flag1 ==  true )
//        stepper.enableOutputs();
//        Serial.println("1");
//        ESP.wdtFeed();
//        yield();
        ESP.wdtDisable();
        stepper.moveTo(value);
        stepper.runToPosition();
//        yield();
//        ESP.wdtFeed();
//        Serial.println("2");
        Serial.println("Stop at:");
        delay(100);
        Serial.print(value);
        flag1 = false;
//        stepper.disableOutputs();
//        Serial.println("3");
        ESP.wdtEnable(1000);
