watchdog error with accelstepper library
Posted: Fri Jul 03, 2020 4:38 am
Hi i have a code like this. I try to control step motor with HA. I am sending step values via mqtt. So far no problem.
But if i dont use "disable watchdog" then i get crash around step no 100 and if i use watchdog i get error around step no 1300.
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
load 0x4010f000, len 3456, room 16
tail 0
chksum 0x84
csum 0x84
va5432625
~ld
wdt reset
tail 0
chksum 0x84
csum 0x84
va5432625
~ld
#include <PubSubClient.h>
#include <AccelStepper.h>
#define Motor1_Dir 5
#define Motor1_Step 4
const char* ssid = "xxx";
const char* password = "xxx";
const char* mqtt_server = "xxx";
const char* mqttUser = "xxx";
const char* mqttPassword = "xxx";
int value;
bool flag1;
AccelStepper stepper(1, Motor1_Step, Motor1_Dir);
WiFiClient espClient;
PubSubClient client(espClient);
void setup_wifi()
delay(10);
Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
randomSeed(micros());
Serial.println("");
void callback(char* topic, byte* payload, unsigned int length)
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
value = 0;
int tensValue = 1;
for (int i = length - 1; i >=0; i--) // iterate backwards
value += (payload[i] - '0') * tensValue ;
tensValue = tensValue * 10;
flag1 = true;
// for (int i = 0; i < length; i++)
// Serial.print((char)payload[i]);
// value = (char)payload [length -1];
// flag1 = true;
// Serial.println();
// Serial.print("Mesaj Geldi");
void reconnect()
while (!client.connected())
Serial.print("Attempting MQTT connection...");
if (client.connect("alkan"))
Serial.println("connected");
client.subscribe("Alkan/perde");
else
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 3 seconds");
delay(3000);
void setup()
setup_wifi();
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
stepper.setMaxSpeed(200);
stepper.setAcceleration(100);
// stepper.setSpeed(200);
void loop()
if (!client.connected())
reconnect();
client.loop();
if( flag1 == true )
// stepper.enableOutputs();
// Serial.println("1");
// ESP.wdtFeed();
// yield();
ESP.wdtDisable();
stepper.moveTo(value);
stepper.runToPosition();
// yield();
// ESP.wdtFeed();
// Serial.println("2");
Serial.println("Stop at:");
delay(100);
Serial.print(value);
flag1 = false;
// stepper.disableOutputs();
// Serial.println("3");
ESP.wdtEnable(1000);
