By GabeZ
#89016 Newbie here, first time I ever soldered anything and playing with the ESP8266.
Plan was to use window/door switches from Sonoff with a Sonoff bridge and connect them to Home Assistant. I followed a guide I found and opened the Sonoff ZigBee Bridge, soldered some cables to the board and connected them to the USB to TLL adapter.
When trying to flash the Tasmote ZigBee Bridge image, this always fails at 12% with A fatal error occurred: Timed out waiting for packet header. I tried a lot of things I found through Google but the results remain the same. Some of them: Keeping the reset button pressed before connecting the USBTTL to my laptop and then try to flash. Connecting the USBTTL without using the reset button. Tried rebooting laptop between tries and read several posts on this but I'm not getting any further. Already spent almost 8 hrs on this step.
Using esptool.py I get the following results:
esptool.py --port /dev/ttyUSB0 chip_id
esptool.py v2.8
Serial port /dev/ttyUSB0
Connecting....
Detecting chip type... ESP8266
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
MAC: a4:cf:12:d9:b9:b6
Uploading stub...
Running stub...
Stub running...
Chip ID: 0x00d9b9b6
Hard resetting via RTS pin...
When I run the command below, I do get a 1MB bin file:
esptool.py --port /dev/ttyUSB0 read_flash 0 0x400000 mybackup.bin
esptool.py v2.8
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
1675264 (39 %)
A fatal error occurred: Corrupt data, expected 0x1000 bytes but received 0xffc bytes
Trying to write to flash:
esptool.py --port /dev/ttyUSB0 write_flash 0 tasmota-zbbridge.bin
esptool.py v2.8
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 2MB
Flash params set to 0x0330
Compressed 540432 bytes to 379979...
Writing at 0x00008000... (12 %)
Trying different baud rates doesn't seem to make a difference:
esptool.py --port /dev/ttyUSB0 --baud 19200 write_flash 0 tasmota-zbbridge.bin
Is there a way I can verify the hardware is still good and I'm just doing the wrong thing?
How can I proof to myself that the wiring is correct to my USBTTL adapter?
Any help is appreciated.
Regards
Gabe
By GabeZ
#89018
schufti wrote:to me it looks like your wiring and commands are ok but your hw (flash on module) is faulty.
the only thing I didn't see is a full erase, you might try
esptool.py --port /dev/ttyUSB0 write_flash 0x0 -e tasmota-zbbridge.bin
Had to change the command slightly to get it to run, moved the "-e" :
I then says:
esptool.py v2.8
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
Erasing flash (this may take a while)...
Chip erase completed successfully in 0.1s
By GabeZ
#89019
(Not sure where my reply went to, but here is another try)
I had to move the "-e" in the command line, but when I run it, I get the following result:
esptool.py v2.8
Connecting....
Chip is ESP8266EX
Features: WiFi
Crystal is 26MHz
Uploading stub...
Running stub...
Stub running...
