This is my ESP8266/Wemos code
#include "MAX30105.h"
#include "heartRate.h"
MAX30105 particleSensor;
const byte RATE_SIZE = 4; //Increase this for more averaging. 4 is good.
byte rates[RATE_SIZE]; //Array of heart rates
byte rateSpot = 0;
long lastBeat = 0; //Time at which the last beat occurred
float beatsPerMinute;
int beatAvg;
WiFiClient client;
char * ssid = "fjarian";
char * password = "rgyp3776";
char * host = "localhost";
void setup()
Serial.println("Initializing...");
if (!particleSensor.begin(Wire, I2C_SPEED_FAST))
Serial.println("MAX30105 was not found. Please check wiring/power. ");
while (1);
Serial.println("Place your index finger on the sensor with steady pressure.");
particleSensor.setup(); //Configure sensor with default settings
particleSensor.setPulseAmplitudeRed(0x0A); //Turn Red LED to low to indicate sensor is running
particleSensor.setPulseAmplitudeGreen(0); //Turn off Green LED
particleSensor.enableDIETEMPRDY();
delay(1000);
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
void loop()
long irValue = particleSensor.getIR();
float temperature = particleSensor.readTemperature();
while (checkForBeat(irValue) == true)
//We sensed a beat!
long delta = millis() - lastBeat;
lastBeat = millis();
beatsPerMinute = 60 / (delta / 1000.0);
if (beatsPerMinute < 255 && beatsPerMinute > 20)
rates[rateSpot++] = (byte)beatsPerMinute; //Store this reading in the array
rateSpot %= RATE_SIZE; //Wrap variable
//Take average of readings
beatAvg = 0;
for (byte x = 0 ; x < RATE_SIZE ; x++)
beatAvg += rates[x];
beatAvg /= RATE_SIZE;
float bpm = beatsPerMinute;
int avgbpm = beatAvg;
Serial.println(host);
WiFiClient client;
const int httpPort = 80;
return;
client.print(String("GET http://localhost/iot_project/connect.php?") +
("&temperature=") + temperature +
("&bpm=") + bpm +
("&avgbpm=") + avgbpm +
" HTTP/1.1\r\n" +
"Host: " + host + "\r\n" +
"Connection: close\r\n\r\n");
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 1000) {
Serial.println(">>> Client Timeout !");
client.stop();
return;
while(client.available()) {
Serial.print(line);
and this is my php code for connection
<html>
<body>
<?php
$dbname = 'example';
$dbuser = 'example';
$dbpass = '';
$dbhost = 'localhost';
$connect = @mysqli_connect($dbhost,$dbuser,$dbpass,$dbname);
if(!$connect){
echo "Error: " . mysqli_connect_error();
exit();
echo "Connection Success!<br><br>";
$temperature = $_GET["temperature"];
$humidity = $_GET["bpm"];
$humidity = $_GET["avgbpm"];
$query = "INSERT INTO iot_project (temperature, bpm, avgbpm) VALUES ('$temperature', '$bpm', '$avgbpm')";
$result = mysqli_query($connect,$query);
echo "Insertion Success!<br>";
</body>
</html>
