I don't think that there is anything wrong with my setup as I was able to send data to a thingspeak channel. This is that same code and setup, adapted to hopefully be able to get data as well.
Please let me know if you need more information.
Serial log:
#include <SoftwareSerial.h>
#define RX 2
#define TX 3
String AP = "ap";
String PASS = "pw";
String HOST = "api.thingspeak.com";
String PORT = "80";
int countTrueCommand;
int countTimeCommand;
boolean found = false;
int buttonState = 0;
int valSensor = 1;
SoftwareSerial esp8266(RX,TX);
pinMode(7, INPUT);
Serial.begin(9600);
esp8266.begin(9600);
sendCommand("AT",5,"OK");
sendCommand("AT+CWMODE=3",5,"OK");
sendCommand("AT+CWJAP=\""+ AP +"\",\""+ PASS +"\"",20,"OK");
void loop()
while (esp8266.available() > 0) {
Serial.println(esp8266.read());
buttonState = digitalRead(7);
if (buttonState == HIGH){
Send();
void Send() {
String res;
String subStr;
int index;
String getData = "GET /apps/thinghttp/send_request?api_key=HPEZ840TM16SIVAU HTTP/1.1";
sendCommand("AT+CIPMUX=1",5,"OK");
sendCommand("AT+CIPSTART=0,\"TCP\",\""+ HOST +"\","+ PORT,15,"OK");
sendCommand("AT+CIPSEND=0," +String(getData.length()+4),4,">");
esp8266.println(getData);
esp8266.println("Host: api.thingspeak.com");
esp8266.println("Connection: keep-alive");
esp8266.println();
delay(1500);countTrueCommand++;
res = esp8266.readString();
index = res.indexOf("formatted");
subStr = res.substring(index+12, index+28);
Serial.println("Raw Result:"+res);
//Serial.println("Filtered Result:"+subStr);
sendCommand("AT+CIPCLOSE=0",5,"OK");
void sendCommand(String command, int maxTime, char readReplay[]) {
Serial.print(countTrueCommand);
Serial.print(". at command => ");
Serial.print(command);
Serial.print(" ");
while(countTimeCommand < (maxTime*1))
esp8266.println(command);
if(esp8266.find(readReplay))
found = true;
break;
countTimeCommand++;
if(found == true)
Serial.println(" => SUCCESS");
countTrueCommand++;
countTimeCommand = 0;
if(found == false)
Serial.println("Fail");
countTrueCommand = 0;
found = false;
