GET request not returning proper result
PostPosted: Thu Jan 14, 2021 6:35 pm
by Kristian2210
As the title describes, I am not getting the expected results from the HTTP request. I am using an ESP 01 module attached to my Arduino UNO. As a test project, I used an API that should give me the amount of Covid 19 infected. However, both filtered and raw results give me random characters, and what seems to be corrupt messages afterward. I really appreciate any good advice that I can get. :D :D
I don't think that there is anything wrong with my setup as I was able to send data to a thingspeak channel. This is that same code and setup, adapted to hopefully be able to get data as well.
Please let me know if you need more information.
Serial log:
Code: Select all#include <SoftwareSerial.h>
#define RX 2
#define TX 3
String AP = "ap";
String PASS = "pw";
String HOST = "api.thingspeak.com";
String PORT = "80";
int countTrueCommand;
int countTimeCommand;
boolean found = false;
int buttonState = 0;
int valSensor = 1;
SoftwareSerial esp8266(RX,TX);
  pinMode(7, INPUT);
  Serial.begin(9600);
  esp8266.begin(9600);
  sendCommand("AT",5,"OK");
  sendCommand("AT+CWMODE=3",5,"OK");
  sendCommand("AT+CWJAP=\""+ AP +"\",\""+ PASS +"\"",20,"OK");
void loop()
  while (esp8266.available() > 0) {
    Serial.println(esp8266.read());
  buttonState = digitalRead(7);
  if (buttonState == HIGH){
    Send();
void Send() {
 String res;
 String subStr;
 int index;
 String getData = "GET /apps/thinghttp/send_request?api_key=HPEZ840TM16SIVAU HTTP/1.1";
 sendCommand("AT+CIPMUX=1",5,"OK");
 sendCommand("AT+CIPSTART=0,\"TCP\",\""+ HOST +"\","+ PORT,15,"OK");
 sendCommand("AT+CIPSEND=0," +String(getData.length()+4),4,">");
 esp8266.println(getData);
 esp8266.println("Host: api.thingspeak.com");
 esp8266.println("Connection: keep-alive");
 esp8266.println();
 delay(1500);countTrueCommand++;
 res = esp8266.readString();
 index = res.indexOf("formatted");
 subStr = res.substring(index+12, index+28);
 Serial.println("Raw Result:"+res);
 //Serial.println("Filtered Result:"+subStr);
 sendCommand("AT+CIPCLOSE=0",5,"OK");
void sendCommand(String command, int maxTime, char readReplay[]) {
  Serial.print(countTrueCommand);
  Serial.print(". at command => ");
  Serial.print(command);
  Serial.print(" ");
  while(countTimeCommand < (maxTime*1))
    esp8266.println(command);
    if(esp8266.find(readReplay))
      found = true;
      break;
    countTimeCommand++;
  if(found == true)
    Serial.println(" => SUCCESS");
    countTrueCommand++;
    countTimeCommand = 0;
  if(found == false)
    Serial.println("Fail");
    countTrueCommand = 0;
  found = false;
Re: GET request not returning proper result
PostPosted: Sun Jan 17, 2021 9:10 am
by JurajA
CIPSEND length doesn't match the data you send
