Page 1 of 2
ESP8266 NodeMCU - Wall switch - Philips Hue
PostPosted: Sun Jan 17, 2021 12:23 pm
by Victorc
Hi everybody,
I just started with the first project with ESP8266, also good to know that I don't have much electronic knowledge for those kind of project. What I try to do is the following. I want to connect pin D1 and the Ground pin to a Wall Switch (which is used normally to turn lights on or off). If the status of the wall switch change, I want to change the status of one philips hue light (meaning: if the light is off, then I want to turn it on if the wall switch is pressed and visa versa).
The code of the ESP8266 is:
#include <SPI.h>
// Wifi Settings
const char* ssid = "xxxxx";
const char* password = "xxxxx";
// Hue Settings
const char hueHubIP[] = "xxxxx"; // Hue Bridge IP
const int hueHubPort = 80;
const char hueUsername[]="xxxxxx";
String light="1";
// Commands
String hue_on="{\"on\":true}";
String hue_off="{\"on\":false}";
boolean state = false; // for monitoring switch state changes
boolean previousState; // ditto
boolean onOffState = false;   // To store actual on/off state of light as reported by Hue bridge
int switchPin = 5; // -- control sense pin, mapped to D1 on NodeMCU
WiFiClient client;
  pinMode(LED_BUILTIN, OUTPUT);     // Initialize LED_BUILTIN pin as output
  Serial.begin(9600);
  pinMode(switchPin, INPUT_PULLUP);
  delay(10);
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  Serial.println("");
  previousState = digitalRead(switchPin);
  digitalWrite(LED_BUILTIN, HIGH);
  Serial.println("State Switch:");
  Serial.println(previousState);
  state = digitalRead(switchPin); // for checking for state change
  if (state != previousState) // state change
    previousState == state;
    getHue();
    if (onOffState == true)                         // If lights are on, send "Off" command
      Serial.println("");
      Serial.print("Switch lamp off");
      String command =  "{\"on\": false}";
      setHue(command);
      digitalWrite(LED_BUILTIN, LOW);
    else                                            // If lights are off, send "On" command
      Serial.println("");
      Serial.print("Switch lamp on");
      String command =  "{\"on\": true}";
      setHue(command);
void setHue(String command)
  if (client.connect(hueHubIP, hueHubPort))
    client.print("PUT /api/");
    client.print(hueUsername);
    client.print("/lights/");
    client.print(light);
    client.println("/state HTTP/1.1");
    client.println("keep-alive");
    client.print("Host: ");
    client.println(hueHubIP);
    client.print("Content-Length: ");
    client.println(command.length());
    client.println("Content-Type: text/plain;charset=UTF-8");
    client.println();                             // Blank line before body
    client.println(command);
    client.stop();
void getHue()
    client.print("GET /api/");
    client.println(" HTTP/1.1");
    client.println("Content-type: application/json");
    client.println();
    while (client.connected())
      if (client.available())
        client.findUntil("\"on\":", "\0");
        onOffState = (client.readStringUntil(',') == "true");
        break;
    client.stop();
When I test this setup, and I connect pin D1 with the Ground, it seems like the status of D1 is changing to high/low constantly (while the wire is still connect to ground). I don't know why this happens.
Can anywhere help me and tell me what I do wrong? Should I not link D1 to Ground, but do this in another way? Or is my coding wrong?
Thanks for the support in advance!
kind regards,
Victor
Re: ESP8266 NodeMCU - Wall switch - Philips Hue
PostPosted: Mon Jan 18, 2021 4:43 am
by btidey
I think the line
should be
previousState = state;
The double equals is a logical test for equivalence but does not update previousState which is what you intended.
PostPosted: Mon Jan 18, 2021 8:04 am
by Victorc
btidey wrote:I think the line
should be
This solved the problem, it is working great now! Thanks for the help, much appreciated!
PostPosted: Wed Mar 03, 2021 11:29 pm
by guysnraw
Why do you want so much mess in programming? Just flash with tasmota, configure switchmode it has lot of options.. :ugeek:
