- Thu Feb 04, 2021 9:08 am
#90413
JurajA wrote:it is io 2, not gpio 2.
Huh?
The ports/pins of an ESP8266 are called GPIO (for "
General
Purpose
Input
Output") and is equivalent to IO or I/O if you like.
With some development boards (like the NodeMCU and Wemos) there's always some confusion between the D (for data) lines and the actual GPIO port they belong to, but the ESP-01 isn't a development board and the pins are just called what they are: GPIO (or I/O or IO, whatever you like).
But, as said: GPIO0 and GPIO2 are best to be pulled high for normal boot (to program the ESP GPIO0 should be pulled low and GPIO *could* have an undetermined state).
GPIO2 acts as a serial debug port (copying GPIO1 at boot), so you might want to pull it up (using a 1k~10k or so resistor) and on the cold end connect a transistor to drive the buzzer; that might possibly work.
But mind that, since GPIO2 is the debug port, you might hear a short buzz at boot, until you've set the pinMode of GPIO2 to OUTPUT.
Something like this (might need some tweaking):
Since you didn't mention what (type of) buzzer module you're using, I've drawn up a generic driver schematic; the resistor to Vcc might not be needed (depending on the signal input of the module).
As for the transistor: any generic NPN type would suffice, like the 2N2222 or the BC547.
Assumption is the mother of all f*ckups. At least: that's what I'm assuming.
