<link rel='icon' href='http://192.168.1.177/ico/favicon.ico'>
to the root header handler and created an action to send the favicon.ico upon a request including "ico/favicon.ico". A const char* literal is transmitted containing the properly formatted icon.
I can request the icon directly from google-chrome via the URL "IP_ADDRESS/ico/favicon.ico". However, when I access "IP_ADDRESS/" I see no attempt in the debug window on google-chrome to request the favicon.
I have installed the same header link and the inc/favicon.ico file on a page served by apache2 on another machine. Chrome properly retrieves the file and displays the icon on the tab of the browser window as I intended.
I have fiddled around trying to get the header of the response to the root request to match as closely to how apache2 responds but have not detected any change in the action on the browser side. I do not know if the browser is not trying or if it is failing silently. I'm rusty on stream capture tools so I cannot easily determine which case it is. I am suspecting it is the latter, trying but failing silently, but I have no evidence to support that.
I am not familiar with Connection: KeepAlive and cannot determine ESP8266WebServer-impl.h can be configured to support keepAlive. I was able to change text for Connect:
sendHeader(String(F("Connection")), String(F("Keep-Alive")));
but that is only a text change, not a change of state. It did make the header more closely match the header returned by apache2 but did not change chrome's behavior.
The server action is as follows:
server.on("ico/favicon.ico", []() {
static const uint8_t ico[] PROGMEM = {
0x00, 0x00, 0x01, 0x00, 0x01, 0x00, 0x10, 0x10, 0x02, 0x00, 0x01, 0x00, 0x01, 0x00, 0xB0, 0x00,
0x00, 0x00, 0x16, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x20, 0x00,
0x00, 0x00, 0x01, 0x00, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0xFF, 0xFF, 0xFF, 0x00, 0xFF, 0xFF, 0x00, 0x00, 0xFF, 0xFF, 0x00, 0x00, 0xFF, 0xFF,
0x00, 0x00, 0xEF, 0xF7, 0x00, 0x00, 0xEF, 0xF7, 0x00, 0x00, 0xEE, 0x77, 0x00, 0x00, 0xEF, 0xF7,
0x00, 0x00, 0xEF, 0xF7, 0x00, 0x00, 0xEF, 0xF7, 0x00, 0x00, 0xE3, 0xCF, 0x00, 0x00, 0xF1, 0x9F,
0x00, 0x00, 0xF0, 0x3F, 0x00, 0x00, 0xFE, 0x7F, 0x00, 0x00, 0xFF, 0xFF, 0x00, 0x00, 0xFF, 0xFF,
0x00, 0x00, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
server.send(200, "image/vnd.microsoft.icon", ico, sizeof(ico));
What response to "GET /" looks like:
<html>
<head>
<title>ESP8266 Furnace</title>
<style> body { background-color: #cccccc; font-family: Arial, Helvetica, Sans-Serif; Color: #000088; }</style>
</head>
<body>
<h1>Low Outside Temperature Furnace Cycling</h1>
<p>Uptime: 00:00:57</p>
<p>Temp C: 18.50 Temp F: 65.30</p>
<p>Zone Thermostat Status: Zone Thermostats Enabled</p> <p>Circulator Status: Forced Circulation not Required</p>
<p>Debug: Entered testTemp with tempC = 5.00</p>
</body>
</html>
Please let me know where I should be looking or what tools I should be using. My workstation is linux.
