By gregorex
#90493 Hello there,
I am new using esp8266 and this world of projects, I appreciated any feedback, I have been dealing with a problem trying to follow this project https://github.com/IU5HKU/MiniWXStation . version of the project bme_V08c.
My situation is the next one: I configured the ESP8266, I upload the sketch and also I connected the sensor BME280, however , When I tried to verify the lectures of the sensor via terminal I got this message:
https://gm1.ggpht.com/SYWaVu9aRDWcMX16KGeqXJ3uz0V-gWaItvUtddg0ppX7rfHsU5XJebmsVlCwUaGs7w_DcaLzwvs0q3xviaBHuD1hlvsaRsJY2452YFAHVHzNbrjPvJJ2VJYvTFRWChCOIx_7WEcz5jcTrT1U7j6RCvO2-6Bb3HFMwdxMWYbGP89GK7C_RBT7IIbGIm2HZENpldBaE1XbuFI9RlIwn72b78FsYtS65jJgoj5u_uc0xfD1jgLHF5NMefUJLfjC5LbkwtwjYmNSGUyb7Wl0NqZmzI_NtXIhRuOqSvho56kfZebM-Pv1WyYaY5gLojCpnrhq6HnhKE3sVfsVmGr1cXoHBoBIBd5cJb7_eH84Cx6VOPr9pCKxTHOv466_mqh2uVAEuMwO46jycgAh7bLy23YRnSUZ4_2p6Mlmjm-c6sZx_px-B-OAMsUGNKbheRbsZ6xToMofvjG0fNCYQmWdg1yQT1d_BG8iWtulMxMmna4gf6vjQ7Ywh_Ruy2pQeUkLRYygf8p0qhbuCkgqjszcpAOr2waU95w9wlYwAKISazeMCRykwJTbwaXw8S1ILMsmJ3Gs_28jUlyXZnR56jA5tViE3p1vBieuzS1z6Uk6hs0oDamI6GysuESAeK9BsgB13-DFbFqT6dqMkWw-54eSq2W3KV9shm1bWw4nPayA7ZbGWzhkRzZI0Ex94jlhdqQBs08j2hiaZxmOS8BVp4PzrhC-Hqw1dZ4xwcQQ4o0QNPQCI9rpk-FNJZLz40jJW_IsQtJkVmFx=s0-l75-ft-l75-ft
But, this lecture is not correct, it looks like the sensor is not working or is not detecting the lectures from the sensor. I bought 3 different sensors, I did test and all of them are showing the same lecture. I tested using another ESP8266 from a friend of mine and I found that all the sensors are in good condition, but I´m not sure what is happening between my ESP8266 and the BME280 . I currently using BMP280 and I´m not getting any lecture, is the same behavior using ESP8266.
I would like to get support on this problem in order to resolve this issue. Thanks a lot for the help in advance.
PD: I tried to make this project using the AMICA NODEMCU ESP8266 and the ESP8266 CH340 V3
Thank you!
