- Fri Apr 23, 2021 10:47 am
#91178
Thank you for your help first of all!
This is the log from the serial monitor
17:43:44.848 ->
17:43:44.848 -> ets Jan 8 2013,rst cause:2, boot mode:(3,7)
17:43:44.848 ->
17:43:44.848 -> ets_main.c
and this is when connecting
C:\Users\RS\AppData\Local\Arduino15\packages\esp8266\tools\python3\3.7.2-post1/python3 C:\Users\RS\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/upload.py --chip esp8266 --port COM7 --baud 921600 --before default_reset --after hard_reset write_flash 0x0 C:\Users\RS\AppData\Local\Temp\arduino_build_662067/sketch_apr17b.ino.bin
esptool.py v2.8
Serial port COM7
Connecting........_____....._____....._____....._____....._____....._____....._____
Traceback (most recent call last):
File "C:\Users\RS\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.7.4/tools/upload.py", line 65, in <module>
esptool.main(cmdline)
File "C:/Users/RS/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 2890, in main
esp.connect(args.before)
File "C:/Users/RS/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/2.7.4/tools/esptool\esptool.py", line 483, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
