I know softserial is unstable. Anyhow, I'm trying to connect my esp12f since many hours to connect to an fingerprint. I enrolled the fingerprints via an pro mini, did set an passwort, everything fine.
But connecting to the esp-12f doesn't work. It simply goes into the OTA Update. Here is my sketch:
This is an example sketch for our optical Fingerprint sensor
Designed specifically to work with the Adafruit BMP085 Breakout
----> http://www.adafruit.com/products/751
These displays use TTL Serial to communicate, 2 pins are required to
interface
Adafruit invests time and resources providing this open source code,
please support Adafruit and open-source hardware by purchasing
products from Adafruit!
Written by Limor Fried/Ladyada for Adafruit Industries.
BSD license, all text above must be included in any redistribution
#include <Adafruit_Fingerprint.h>
#include <SPI.h>
#include <Wire.h>
#include <WiFiClient.h>
#include <PubSubClient.h> // Aus Wifi Mqtt
#include <ESP8266WebServer.h>
#include <ArduinoOTA.h>
#include <SoftwareSerial.h>
SoftwareSerial mySerial(12, 13);
//tx - mosi PIN 13 - rc503 grün - rx
//rx - miso PIN 12 - rc503 gelb - tx
Adafruit_Fingerprint finger = Adafruit_Fingerprint(&mySerial, "myPasswordInDigits");
/* Set these to your desired credentials. */
const char *ssid = "ssid"; //ENTER YOUR WIFI SETTINGS
const char *password = "mypassword";
const char* mqttServer = "mymqtt"; // Broker PI
const int mqttPort = 1883; // Broker PI Port
const char* mqttUser = "FP"; // Broker PI Name
const char* mqttPassword = "pwd"; // Broker PI Password
WiFiClient espClient;
PubSubClient client(espClient);
char* mqttio = "12345"; // Broker PI Wert
char* confidence = "67890"; // Broker PI Wert
uint8_t id;
void setup()
// Serial.begin(115200);
// Serial.println("\n\nConnect to Wifi");
connectToWiFi();
// mqtt
client.setServer(mqttServer, mqttPort);
client.setCallback(callback);
while (!client.connected()) {
// Serial.println("Connecting to MQTT...");
if (client.connect("ESP8266Client", mqttUser, mqttPassword )) {
// Serial.println("connected");
} else {
// Serial.print("failed with state ");
// Serial.print(client.state());
// Serial.print("looking for update ");
ArduinoOTA.onStart([]() {
String type;
if (ArduinoOTA.getCommand() == U_FLASH) {
type = "sketch";
} else { // U_FS
type = "filesystem";
// NOTE: if updating FS this would be the place to unmount FS using FS.end()
Serial.println("Start updating " + type);
ArduinoOTA.begin();
while(1) {
ArduinoOTA.handle();
delay(50);
// Serial.println("\n\nAdafruit finger detect test");
// set the data rate for the sensor serial port
delay(1000);
mySerial.begin(57600, SWSERIAL_8N1, 12, 13, false, 256, 256);
finger.begin(57600);
if (finger.verifyPassword()) {
// Serial.println("Found fingerprint sensor!");
// send command to turn on R503 led
finger.led_control(1,100,2,1); // code(1-6),speed(1-255),color(1-R/2-B/3_P),time(1-255)
} else {
// Serial.println("Did not find fingerprint sensor :(");
client.subscribe("Error");
client.publish("Error", "No FP");
delay(60000);
String type;
type = "sketch";
} else { // U_FS
ArduinoOTA.begin();
while(1) {
delay(50);
finger.getTemplateCount();
// Serial.print("Sensor contains "); // Serial.print(finger.templateCount); // Serial.println(" templates");
// Serial.println("Waiting for valid finger...");
client.subscribe("Fingerprint");
client.publish("Fingerprint", "FP1");
void callback(char* topic, byte* payload, unsigned int length) {
// Serial.print("Message arrived in topic: ");
// Serial.println(topic);
// Serial.print("Message:");
for (int i = 0; i < length; i++) {
// Serial.print((char)payload[i]);
// Serial.println();
// Serial.println("-----------------------");
void loop() // run over and over again
//check if there's a connection to WiFi or not
if(WiFi.status() != WL_CONNECTED){
connectToWiFi();
if (!client.connected()) {
client.connect("ESP8266Client", mqttUser, mqttPassword );
if (getFingerprintIDez() == 9) {
delay(2000);
getFingerprintEnroll();
delay(50); //don't ned to run this at full speed.
// returns -1 if failed, otherwise returns ID #
int getFingerprintIDez() {
uint8_t p = finger.getImage();
if (p != FINGERPRINT_OK) return -1;
p = finger.image2Tz();
p = finger.fingerFastSearch();
if (p != FINGERPRINT_OK) {
finger.led_control(1,100,1,3); // code(1-6),speed(1-255),color(1-R/2-B/3_P),time(1-255)
return -1;
// found a match!
// Serial.print("Found ID #"); // Serial.print(finger.fingerID);
// Serial.print(" with confidence of "); // Serial.println(finger.confidence);
finger.led_control(1,100,2,3); // code(1-6),speed(1-255),color(1-R/2-B/3_P),time(1-255)
// mqtt
sprintf(mqttio,"%d",finger.fingerID);
sprintf(confidence,"%d",finger.confidence);
client.subscribe("Confidence");
client.publish("Confidence", confidence);
client.subscribe("FingerprintNr");
client.publish("FingerprintNr", mqttio);
return finger.fingerID;
void connectToWiFi(){
WiFi.mode(WIFI_OFF); //Prevents reconnection issue (taking too long to connect)
delay(1000);
WiFi.mode(WIFI_STA);
// Serial.print("Connecting to ");
// Serial.println(ssid);
WiFi.begin(ssid, password);
// Serial.print(".");
// Serial.println("");
// Serial.println("Connected");
// Serial.print("IP address: ");
// Serial.println(WiFi.localIP()); //IP address assigned to your ESP
uint8_t getFingerprintEnroll() {
finger.led_control(1,100,3,3); // code(1-6),speed(1-255),color(1-R/2-B/3_P),time(1-255)
id = min(finger.templateCount + 1, 127);
int p = -1;
// Serial.print("Waiting for valid finger to enroll as #"); // Serial.println(id);
while (p != FINGERPRINT_OK) {
switch (p) {
case FINGERPRINT_OK:
// Serial.println("Image taken");
break;
case FINGERPRINT_NOFINGER:
// Serial.println(".");
break;
case FINGERPRINT_PACKETRECIEVEERR:
// Serial.println("Communication error");
break;
case FINGERPRINT_IMAGEFAIL:
// Serial.println("Imaging error");
break;
default:
// Serial.println("Unknown error");
break;
// OK success!
p = finger.image2Tz(1);
switch (p) {
// Serial.println("Image converted");
break;
case FINGERPRINT_IMAGEMESS:
// Serial.println("Image too messy");
return p;
return p;
case FINGERPRINT_FEATUREFAIL:
// Serial.println("Could not find fingerprint features");
return p;
case FINGERPRINT_INVALIDIMAGE:
return p;
default:
return p;
// Serial.println("Remove finger");
delay(2000);
p = 0;
while (p != FINGERPRINT_NOFINGER) {
// Serial.print("ID "); // Serial.println(id);
p = -1;
// Serial.println("Place same finger again");
switch (p) {
break;
break;
break;
break;
default:
break;
// OK success!
p = finger.image2Tz(2);
switch (p) {
break;
return p;
return p;
return p;
return p;
default:
return p;
// OK converted!
// Serial.print("Creating model for #"); // Serial.println(id);
p = finger.createModel();
if (p == FINGERPRINT_OK) {
// Serial.println("Prints matched!");
} else if (p == FINGERPRINT_PACKETRECIEVEERR) {
return p;
} else if (p == FINGERPRINT_ENROLLMISMATCH) {
// Serial.println("Fingerprints did not match");
return p;
} else {
return p;
p = finger.storeModel(id);
// Serial.println("Stored!");
return p;
} else if (p == FINGERPRINT_BADLOCATION) {
// Serial.println("Could not store in that location");
return p;
} else if (p == FINGERPRINT_FLASHERR) {
// Serial.println("Error writing to flash");
return p;
} else {
return p;
}Any help is appreciated.
Marc
