Thank you
Thank you
Explore... Chat... Share...
Dynamo wrote:I am planning to use the ESP8266 ESP-12E.
Dynamo wrote:I would like to know your opinion if there could be problems using the encoder and the gy-521 , as the encoder will make a lot of interference when rotating, right?
#include "Wire.h"
void setup(){
while(!Serial){} // Waiting for serial connection
Serial.println("Start I2C scanner ...");
Serial.print("\r\n");
byte count = 0;
Wire.begin();
for (byte i = 8; i < 120; i++)
Wire.beginTransmission(i);
if (Wire.endTransmission() == 0)
Serial.print("Found I2C Device: ");
Serial.print(" (0x");
Serial.print(i, HEX);
Serial.println(")");
count++;
delay(1);
Serial.println("Finish I2C scanner");
Serial.print("Found ");
Serial.print(count, HEX);
Serial.println(" Device(s).");
void loop() {}It takes about 20-25 seconds for home assistant c[…]
