By Pettefar
#91381 Hi, I just received an ESP8266 ESP-07 Serial WiFi module from Open-Smart. It has for pins on it, a reset switch and another slide switch.
Does anyone know this item?
Can it be programmed from the Arduino IDE?
Regards,
Nick
Dublin
By JurajA
#91383 yes it can be programmed. you need a USB-to-TTL-Serial adapter.
it has 5 V powering and 5 V logic level conversion and a switch for io 0 to put the esp8266 in flashing mode.
By QuickFix
#91402 FWIW The ESP-07 is only the portion on this board with the metal can on it. :idea:
