I don't use that board myself but an on-line picture shows it is pretty simple. Here are my guesses.
Below the memory chip I think are two leds and two 12K resistors.
The capacitors either side of the crystal oscillator would typically be about 10pF
The resistor to the right of the oscillator is a 12K used to ties RES12K pin to GND
The capacitor above the CPU is probably a 3.3V power decoupling capacitor. One could verify this by checking the pads with a meter and if so they would go to the 3v3 and GND pins. Typically they would put either a 4u7 or 10u capacitor here.
But as said a picture of the damaged board would be helpful
