Doing it over HTTP would be pretty easy. Make a PHP script that keeps an eye on the files you're interested in. Then have the ESP8266 pull up that page and fetch a value from it, then react accordingly.
For example, I have a remote sensor that works on variable deep sleep intervals. When the board uploads the current readings, the server stores them and returns it a value for when it wants the board to check in next. Example below.
Hope it helps!
Code: Select all HTTPClient http;
http.begin("http://192.168.210.5/collector.php?readings={\"air\":\"" + readingsAir + "\",\"light\":\"" + readingsLight + "\"}");
int httpCode = http.GET();
String payload = http.getString();
http.end();
naptime = naptime*1000000;
Serial.println("Napping for " + String(naptime) + "us");
ESP.deepSleep(naptime, WAKE_NO_RFCAL);
