Unable to get data from webserver at certain networks
PostPosted: Thu Jan 20, 2022 10:01 am
by EduardoEG
Hi!
I have this code running on my NodeMCU:
#include <ESP8266WebServer.h>
#include <DNSServer.h>
#include <strings_en.h>
#include <WiFiManager.h>
#define INTERVALO_WIFI 30000
bool controle_auto_rec = false;
bool shouldSaveConfig = false;
const int PIN_AP = 14;
ESP8266WebServer server(80);
char htmlResponse[1000];
unsigned int tempo_decorrido = 0;
void handleRoot() {
  snprintf(htmlResponse, 1000,
  "<!DOCTYPE html>\
  <html lang=\"en\">\
    <head>\
      <meta charset=\"utf-8\">\
      <meta name=\"viewport\" content=\"width=device-width, initial-scale=1\">\
    </head>\
    <body>\
            <h1>Mensagem</h1>\
            <input type='text' name='msg_to_send' id='msg_to_send' size=2 autofocus> mensagem \
            <div>\
            <br><button id=\"send_button\">Enviar</button>\
            </div>\
      <script src=\"https://ajax.googleapis.com/ajax/libs/jquery/1.11.3/jquery.min.js\"></script>\
      <script>\
        var txt;\
        $('#send_button').click(function(e){\
          e.preventDefault();\
          txt = $('#msg_to_send').val();\
          $.get('/send?txt=' + txt, function(data){\
            console.log(data);\
      </script>\
    </body>\
  </html>");
   server.send(200, "text/html", htmlResponse);
void handleSend() {
  Serial.println("Handle send");
  if (server.arg("txt")!= "")
    Serial.println("Mensagem: " + server.arg("txt"));
  delay(10);
  pinMode(PIN_AP, INPUT);
  WiFiManager wifiManager;
  wifiManager.setAPCallback(configModeCallback);
  wifiManager.setSaveConfigCallback(saveConfigCallback);
  wifiManager.autoConnect("ESP_AP","12345678");
  server.on ( "/", handleRoot );
  server.on ("/send", handleSend);
  server.begin();
  Serial.println ( "HTTP server started" );
  if(WiFi.getMode() == WIFI_STA && WiFi.status() == WL_CONNECTED && controle_auto_rec == false)  {
    Serial.println("Setar persistencia");
    WiFi.setAutoReconnect(true);
    WiFi.persistent(true);
    controle_auto_rec = true; }
  if((WiFi.getMode() == WIFI_AP || WiFi.status() != WL_CONNECTED) && controle_auto_rec == true)  {
    Serial.println("Setar controle false");  }
  if((millis() - tempo_decorrido >= INTERVALO_WIFI) && WiFi.status() != WL_CONNECTED && WiFi.getMode() == WIFI_STA) {
    Serial.println("Reconectando");
    WiFi.reconnect();
    tempo_decorrido = millis(); }
  if(digitalRead(PIN_AP) == HIGH)  {
      Serial.println("resetar");
      wifiManager.resetSettings();
      ESP.restart();  }
  server.handleClient();
void configModeCallback (WiFiManager *myWiFiManager) {
  Serial.println("Entrou no modo de configuração");
  Serial.println(WiFi.softAPIP());
  Serial.println(myWiFiManager->getConfigPortalSSID());
void saveConfigCallback () {
  Serial.println("Configuração salva");
When I connect both ESP and my PC in my main network, messages send by the WebServer are shown on the Serial Monitor. When I connect both ESP and PC to my smartphone hotspot (without internet connection), "handleSend" is never called, even though the WebServer can be accessed . How can I make sure to aways be able to communicate with the ESP through the server?
Re: Unable to get data from webserver at certain networks
PostPosted: Sat Jan 22, 2022 9:02 am
by rpiloverbd
Hello, Looks like the users of this thread faced a similar problem ( not the same though)
viewtopic.php?f=6&t=22310
Here is also a project featuring ESP8266 based web server. If you find no clue from here you can post your question here too:
https://www.pcbway.com/project/sharepro ... 6_12E.html
