Can't connect D1 Mini NodeMcu ESP8266-12F with computer
Posted: Fri May 06, 2022 1:52 pm
Hello,
I am trying to make a circuit with a serial commuication between a arduino and a esp8226 (they are not yet connected), but currently I am struggling to even connect the esp8266 with my computer. I already added the "Additional Board Manager URL" which was given in the instructions, downloaded the "esp8266 board manager". When I am plugging in the usb cabel from the esp8266 to my computer, other via usb connected devices disconnect, like my arduino.
Output from lsusb before connecting the esp:
Output from lsusb after connecting the esp:
The same happens when i try to connect the esp8266 on another computer, which is running windows:
It would be great if somebody could tell me what am i doing wrong. Thanks in advance.
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 046d:c077 Logitech, Inc. M105 Optical Mouse
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 019: ID 2341:0043 Arduino SA Uno R3 (CDC ACM)
Bus 001 Device 002: ID 046d:c328 Logitech, Inc. Corded Keyboard K280e
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
# during the plugged in esp8266
PS C:\Users\user> Get-PnpDevice -PresentOnly | Where-Object { $_.InstanceId -match '^USB' }
Status Class FriendlyName InstanceId
OK CDROM hp DVDRW GUE1N USB Device USBSTOR\CDRO...
OK USB Generischer USB-Hub USB\VID_05E3...
OK Camera HP TrueVision HD Camera USB\VID_04F2...
OK USB USB-Root-Hub (USB 3.0) USB\ROOT_HUB...
OK USB USB-Massenspeichergerät USB\VID_04B7...
OK Bluetooth Realtek Bluetooth 4.2 Adapter USB\VID_0BDA...
OK USB USB-Verbundgerät USB\VID_04F2...
# after removing the esp8266
OK HIDClass USB-Eingabegerät USB\VID_062A...
OK USB USB-Verbundgerät USB\VID_062A...
