I'm trying to read data from my mitutoyo height gauge using the following code:
// Derived from https://www.instructables.com/id/Interfacing-a-Digital-Micrometer-to-a-Microcontrol/
#include <SPI.h>
#include <Wire.h>
#include <Arduino.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
// Declaration for an SSD1306 display connected to I2C (SDA, SCL pins)
// The pins for I2C are defined by the Wire-library.
// On an arduino UNO: A4(SDA), A5(SCL)
// On an arduino MEGA 2560: 20(SDA), 21(SCL)
// On an arduino LEONARDO: 2(SDA), 3(SCL), ...
#define OLED_RESET 4 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3C ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// When defined, will send SPC data as hexadecimal over serial.
#define HEX_DATA_OUTPUT
// When defined, will convert raw data to human readable string
// and send over serial.
#define HUMAN_READABLE_OUTPUT
int req = 5; //Arduino pin for REQ line, drives transistor to ground SPC port pin 5 (~REQ)
int dat = 2; //Arduino pin for Data line, connects directly to SPC port pin 2 (DATA)
int clk = 3; //Arduino pin for Clock line, connects directly to SPC port pin 3 (~CLK)
int i = 0;
int j = 0;
int k = 0;
// Mitutoyo SPC data port transmits 13 4-bit values
// Byte Meaning
// 0 Header, always 0xF
// 1 Header, always 0xF
// 2 Header, always 0xF
// 3 Header, always 0xF
// 4 Sign. Zero is positive. 0x8 is negative.
// 5 Most significant digit (MSD) of measurement
// 6 Next digit of measurement
// 7 Next digit of measurement
// 8 Next digit of measurement
// 9 Next digit of measurement
// 10 Least significant digit (LSD) of measurement
// 11 Digit to place decimal point
// 12 Unit. Zero is mm. Nonzero (b1000 is 1?) is inch
byte spcdata[13]; // The raw data sent by instrument
#ifdef HUMAN_READABLE_OUTPUT
float value; // The value calculated from raw data
int decimal; // Number of digits that are after decimal point
#endif
Serial.begin(9600);
pinMode(req, OUTPUT);
pinMode(clk, INPUT_PULLUP);
pinMode(dat, INPUT_PULLUP);
digitalWrite(req,LOW); // set request at high
// SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
if(!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
// Clear the buffer
display.clearDisplay();
display.setTextSize(3); // Draw 2X-scale text
display.setTextColor(SSD1306_WHITE);
getData();
#ifdef HEX_DATA_OUTPUT
for( i = 0; i < 13; i++ ) {
Serial.print(spcdata[i],HEX);
// Need a separator if we're printing human readable as well
Serial.print(" ");
#endif // HUMAN_READABLE_OUTPUT
#endif //HEX_DATA_OUTPUT
// Combine measurement digits into a number
value = 0;
for( i = 5; i <= 10; i++) {
value *= 10;
value += spcdata[i];
// Adjust number for decimal point position
decimal = spcdata[11];
value /= pow(10,decimal);
// Adjust if number is negative
if (spcdata[4] == 0x8) {
value *= -1;
// Print resulting value to serial port, to specified
// number of digits after decimal point.
display.setCursor(0, 0);
Serial.print(value,decimal);
display.println(value,decimal);
// Append units for value
if (spcdata[12] == 0) {
Serial.print(" mm");
display.print(" mm");
} else {
Serial.print(" in");
display.print(" in");
display.display(); // Show initial text
void getData(void){
digitalWrite(req, HIGH); // generate set request
k = 0;
// Timing diagram indicates data bit has been valid for about 120
// microseconds before the clock signal is raised, and remains
// valid for about 120 microseconds afterwards. This code reads data
// bit at the falling clock edge.
for (j = 0; j < 4; j++) {
while( digitalRead(clk) == LOW) {
} // hold until clock is high
while( digitalRead(clk) == HIGH) {
} // hold until clock is low
bitWrite(k, j, (digitalRead(dat) & 0x1));
// After reading the first 4-bit value, we can drop REQ output.
if (i == 0) {
spcdata[i] = k;
}but whenever I upload the code on my NODEMCU, it crashes every few seconds with a soft WDT reset message. Can anyone please help me why that is?
Thanks in advance!
