Interested in the issue of adapting the code from arduino pro micro for esp8266.
As I understand it, esp8266 does not support working with ports, it simply does not have them.
The code for working with DDRB PORTB or DDRD PORTD does not work, incl. gives a compiler error.
uint8_t pd = PIND & B10100; // pins 2 and 4 direct reading
((pd == B10100) || (pd == B00000)) ? encoderPos++ : encoderPos--;In general, of course, it’s interesting, ESP8266 is a fairly powerful module with 80 MHz CPU and Wi-Fi on board, but it cannot process the same code as in a slower arduino UNO or PRO MICRO - 16 MHz and without Wi-Fi.
Give advice on how to be.
Or the code does not solve the problem, and it is necessary to combine the ESP8266 and UNO together in the hardware?
Also a question - maybe someone came across the N5110_SPI library?
https://github.com/cbm80amiga/N5110_SPI
I connect the pins of the RST/CE/DC in digital pins on ESP8266.
And connect the pins of the DIN/CLK in hardware SPI pins.
The display Nokia 5110 does not show an image.
Tell me some advice on how to be, or is there only one solution - to take a board from atmega 328p and ESP8266 on board?
