Page 1 of 3
Flash ESP-12F with a D1 Mini
PostPosted: Mon Oct 03, 2022 2:18 am
by Gromit_
Hello,
would it be posible to flash an ESP-12F with a D1 Mini? I know that it is posible with the NodeMCU board: https://circuitjournal.com/esp8266-with ... th-nodemcu
But the D1 Nano doesn't have the pin EN to disable the chip.
I have read some comments that it could be posible but both boards would get flashed at the same time, what wouldn't be a problem.
Is it really posible and safe?
Thank you
Re: Flash ESP-12F with a D1 Mini
PostPosted: Thu Oct 06, 2022 2:17 am
by rooppoorali
Looks like nobody has uploaded any tutorial for this task.
PostPosted: Fri Oct 07, 2022 3:02 am
by Gromit_
I have been doing some tests and with the help from the Arduino forum (link) I came to this setup that seems to work:
Flash mode:
1. Move the switch to the left (GPIO0 to GND)
2. Press the reset button.
3. Click on upload in the IDE program in the computer to flash the ESP-12F.
Normal mode:
Switch in the right position (GPIO0 floating) => ESP-12F boats in normal mode and runs the code.
Any advice or suggestion are welcome!
PostPosted: Fri Oct 07, 2022 8:13 am
by QuickFix
I suggest you get yourself a FTDI board and flash it the old fashioned way; you don't want to mess with the half baked solutions like using Arduino UNO's and D1 mini's, especially when you're a newbie.
For what it's worth: In theory the procedure for using a D1 mini should be similar to that of a NodeMCU; the only real difference is that the ESP chip is not encapsulated inside a metal box. :idea:
Just my two cents.
