- Mon Aug 31, 2020 8:04 pm
#88618
eriksl wrote:Ah ok, I see.
BTW I just "found out" (ok, I could have known) that if you start the access point mode instead of station mode, you will lose another 4k
. So if you have an optional AP mode (like me) you need to take this 4k in account too.
The way I have handled that is to split my system into two completely separate boot areas. I use AP mode during set up and configuration only, so I have the whole set up system as one partition, and the normal run time as a second (and OTA as third using rboot). I then reboot into the different partitions as needed.
That works for how I use the AP mode, but probably won't for everybody
