I've gone to great lengths to try and get a web server to be perfectly stable. Considering, at the lowest level, it depends on lwIP, TCP, IP, link layer, ESP hardware, router and airwave congestion, perfect stability is impossible. A simple collision on the WiFi airwaves can loose a packet that requires a resend which bubbles up to the top in the form of a momentary pause in the transfer of data.
I would assume that the time base is tied to something immune to pausing... like a crystal. However, there are a lot of steps between the crystal and code getting a return u32 millis(). I wanted to check with the Advanced experts on this forum to see if my assumption is correct.
Thanks,
w/ GUI Admin Client, Drag & Drop File Manager, OTA Built-In, Access Point Manager,
Performance Metrics, Web Socket Comms, App API, All running on ESP8266...
Even usable on ESP-01S --- Please check it out!
https://inqonthat.com/inqportal-the-three-line-promise/
https://InqOnThat.com/inqportal
