delinend wrote:Wow ! I have tryed many hardware things... Pull up/down on GPIO0, GPIO2, GPIO15 an RST. Also a 470pF capasity on the RST to GND. All without luck
My ESP-07 is going intozombie mode, after 5-8 minutes, with 1 minute deepsleep.
But the I suddenly tryes to flash "INTERNAL://DEFAULT" and "INTERNAL://BLANK" via NodeMCUflasher. And now my ESP-07 has rund for 5 days with 1 minut deepsleep loop, without any problems I have also removed all pull up/down from my board. Only a pull down 12Kohm on GPIO15.
(Select the 0x7C000 default and 0x7E000 blank sections. Uncheck the box for the 0x10000 IROM section.)
I followed this: http://benlo.com/esp8266/esp8266QuickStart.html
Please try it !!
HI,
I am not completely clear with your proposal !
You mentionned to follow Benlo's link and use NodeMCUflasher. Do you mean ESP8266Flasher.exe ?
If yes your advice is to reflash only DEFAULT and BLANK and to uncheck IROM ? And what about INTERNAL/FLASH ?
JP
