By alonewolfx2
#7081 I tried power cycle and node.restart more than 10 repeat and its working fine. it seems problem solved.
By kmpm
#7107 I just compiled the latest from git ( a2d1e5ff2b ) v0.9.5, using the compiler I got from esp-open-sdk (gcc) and I flashed using the esptool.py way.
Code: Select allmake
make flash
Then I uploaded a small init.lua script that just connects to my wireless and prints the IP once every second.
I was able to do > 50 power cycles without any issues.
By hamishcunningham
#7123 I've been getting the same problem, and the user_main.c fix doesn't work for me :-(
I commented out those lines, recompiled and reflashed (make, make flash), but it didn't make any difference.
The only way I can get it to restart is to go into flash mode (with the relevant pin held low) and then back to normal mode. The first restart after that works, but subsequently it hangs in the same way that others have reported.
Any ideas?
Cheers
Hamish
