By sancho
#5956 This is strange.
When I write a function with the same output as the code above and only do the sending part, it got sent correctly:
Code: Select allfunction sendData()
    output="18-FE-34-98-E5-16\t100e2951010800\t24.1250\n"
    output= output .. "18-FE-34-98-E5-16\t28abb595010000\t23.4375\n"
    sk=net.createConnection(net.TCP, 0)
    sk:on("receive", function(sck, c) print(c) end )
    sk:connect(8888, "192.168.11.1")
    sk:send(output)
    sk:on("sent", function(conn) print "Closing connection" conn:close() end)
sendData()
Does anyone have any tips? I am out of ideas :(
By sancho
#5958 I modified the original "problematic" script in a bit "assynchronous" way and it is working.
Code: Select allpin = 4
ow.setup(pin)
output = nil
function bxor(a,b)
   local r = 0
   for i = 0, 31 do
      if ( a % 2 + b % 2 == 1 ) then r = r + 2^i end
      a = a / 2
      b = b / 2
   return r
function getTemp()
      sensors={}
      temps={}
      counter=0
      addr = ow.reset_search(pin)
      repeat
      tmr.wdclr()
      if (addr ~= nil) then
        crc = ow.crc8(string.sub(addr,1,7))
        if (crc == addr:byte(8)) then
          if ((addr:byte(1) == 0x10) or (addr:byte(1) == 0x28)) then
      sensor = ""
      for j = 1,7 do sensor = sensor .. string.format("%02x", addr:byte(j)) end
                sensors[counter] = sensor
                ow.reset(pin)
                ow.select(pin, addr)
                ow.write(pin, 0x44, 1)
                tmr.delay(1000 * 1000)
                present = ow.reset(pin)
                ow.write(pin,0xBE, 1)
                data = nil
                data = string.char(ow.read(pin))
                for i = 1, 8 do data = data .. string.char(ow.read(pin)) end
                crc = ow.crc8(string.sub(data,1,8))
                if (crc == data:byte(9)) then
                   t = (data:byte(1) + data:byte(2) * 256)
         if (t > 32768) then
                    t = (bxor(t, 0xffff)) + 1
                    t = (-1) * t
         t = t * 625
                   if(addr:byte(1) == 0x10) then
                     -- we have DS18S20, the measurement must change
                     t = t * 8;  -- compensating for the 9-bit resolution only
                     t = t - 2500 + ((10000 * (data:byte(8) - data:byte(7))) / data:byte(8))
                   temps[counter] = t
      addr = ow.search(pin)
      counter = counter + 1
      until(addr == nil)
    output = ""
    for i, sensorID in ipairs(sensors) do
        t1 = temps[i] / 10000
        t2 = (temps[i] >= 0 and temps[i] % 10000) or (10000 - temps[i] % 10000)
        output = output .. wifi.sta.getmac()
        output = output .."\t" .. sensorID .. "\t"
        output = output .. t1 .. "." .. string.format("%04d", t2) .. "\n"
    output = output .. "#"
function sendData()
    if(output ~= nil) then
        if(string.byte(output, -1) == string.byte("#")) then
            print("About to send:\n" .. output)
            sk:send(output)
            output = nil
function checkIP()
    if wifi.sta.getip() ~= nil then
        tmr.stop(0)
        tmr.wdclr()
        print("Got IP")
        print(wifi.sta.getip())
        print("Starting Temp measurement")
        getTemp()
        tmr.alarm(0,5*1000, 1, sendData)
        tmr.alarm(1,30*1000, 1, getTemp)
tmr.alarm(0, 2 * 1000, 1, checkIP)
However, when removing the first alarm and calling sendData() directly after the measurement, the connection does not work.
Any tips, what is wrong?
Perhaps some timer issue?
By alonewolfx2
#5966 i am using like this. its working with 20141230 firmware
ow.setup(pin)
counter=0
lasttemp=-999
function bxor(a,b)
   local r = 0
   for i = 0, 31 do
         r = r + 2^i
      a = a / 2
      b = b / 2
   return r
function getTemp()
        tmr.wdclr()
        ow.reset(pin)
        ow.skip(pin)
        ow.write(pin,0x44,1)
        tmr.delay(800000)
        ow.reset(pin)
        ow.skip(pin)
        ow.write(pin,0xBE,1)
        data = nil
         if (t > 32768) then
                    t = (-1) * t
         t = t * 625
                   lasttemp = t
         print("Last temp: " .. lasttemp)
srv=net.createServer(net.TCP)
srv:listen(80,function(conn)
conn:on("receive",function(conn, payload)
getTemp()
    t1 = lasttemp / 10000
    t2 = (lasttemp >= 0 and lasttemp % 10000) or (10000 - lasttemp % 10000)
    conn:send("Temperature: " .. t1 .. "." .. string.format("%04d", t2) .. "\n\n")
end)
conn:on("sent",function(conn)
    conn:close()
  end)
end)
